Stalling and idle hunting help!
Postby Russ101 » Thu Apr 05, 2018 6:27 pm
Hi guys
Hoping some one can help.
I have a 14 plate 2.2.
Every few days on idle the revs raise and fall between 800 to 1200 rpm. No clutch pressed etc.
Also has been stalling when pulling up to junctions etc. Plugged it into a snap on computer and a MAF fault so replaced that and recalibrated that, again with snap on computer.
Only other fault that comes up in a diesel intake valve ( think that’s what it was defo not egr ) tried recallabrating that and it worked for about 1 month but the faults back. Tried a recalibration and it’s lasted a day.
Have googled it but nothing to do with that valve pops up.
Anybody have any ideas before I replace the valve?
Thanks Russ
Russ101
Re: Stalling and idle hunting help!
Postby 70slovebug@gmail.com » Mon Jun 04, 2018 4:16 pm
Hi Russ,
Did you ever get to the bottom of this?
As ours is hunting at idle too, been back 3 times and they can not get it to replicate the fault and there-fore cant fix it.
Cheers, Kay
cron
