Wierd connecter behind headlight
Postby KevofCov » Tue Apr 17, 2018 10:08 pm
2.2 125hp LWB RWD ‘65
Can anybody shed light on this connector. Its behind the OS headlight next to the radiator. It has five wires in and only two out but has a number of ‘plastic’ match sticks sticking out the side. This is as it left the factory I believe.
KevofCov
Re: Wierd connecter behind headlight
Postby loot » Tue Apr 17, 2018 10:42 pm
Can't tell you what it's for but the end with the matches is probably a blank with pin protectors, I'll bet that all comes off then you plug in the connector which isn't needed on your van as it is, whatever it is.
Ids map here
loot
cron
