Ford transit 2015 sliding door saying open even when closed
Postby christophergough » Sun Apr 22, 2018 9:38 am
Hi all
My company gave me another van on friday after having numerous on going faults with the mk7 i had, anyway back to the mk8 the sliding door is closed but keeps alarming on the dash once pulled away and when its locked the horn blasts to tell you a door is open, ive tried to have a look but cannot seem to find what signals that the door is open/shut, I've cleaned the 3 metal contact on the pillar and the 3 pins on the door, ive also used wd40 on the door locking mechanism but none have worked. All the doors lock. Also the door all lines up.
Any help would very much be appreciated
Sent from my LG-H870 using Tapatalk
christophergough
Re: Ford transit 2015 sliding door saying open even when clo
Postby Frag » Sun Apr 22, 2018 1:00 pm
The mk8 and custom have a old school door pin switch,on right hand edge of door opening,
The plunger has a habit of breaking or coming off.
Also the long bolt,that goes through the centre roller / hinge on rear edge of door,has a habit of winding itself out thru opening and closing of the door,
This bolt adjusts the height of the door in frame,usually the catch goes out of alignment with the striker.
Frag
Ford Technician
Postby christophergough » Mon Apr 23, 2018 6:32 pm
Frag wrote:The mk8 and custom have a old school door pin switch,on right hand edge of door opening,
Hi frag
So I've managed to habe a look today, i took off the rubber stopper on the right hand side at the top but its just a solid piece of rubber that doesnt move, is this the part you meant or is it somewhere else? Ive looked at the runner and doesnt look like its moved at all but didnt want start moving to much of it until i knew where the pluger is
Chris
christophergough
Postby Frag » Mon Apr 23, 2018 6:56 pm
This is the switch.....
Frag
Ford Technician
Postby christophergough » Mon Apr 23, 2018 6:57 pm
Frag wrote:This is the switch.....
Thanks again will have a look again tomorrow
christophergough
Postby Frag » Mon Apr 23, 2018 6:58 pm
And this is its location,but pic is a LHD van or OS sliding door,
So mirror image of this...
Frag
Ford Technician
Postby christophergough » Mon Apr 23, 2018 7:52 pm
Frag wrote:And this is its location,but pic is a LHD van or OS sliding door,
Thats brilliant dont how i missed it
christophergough
Postby christophergough » Mon Apr 23, 2018 8:12 pm
Hi frag
Well i thought id go have a look and well there was no plunger switch, but what i did find is the previous driver had retro fitted it on a rocker switch as you can see in the photo, thanks for all your help again, probably would of never found it.
ChrisImageImage
christophergough
Postby Frag » Mon Apr 23, 2018 9:01 pm
Not quite the outcome is was expecting....
So,you can have it set to door open,or closed regardless of position of actual door,
Which means you could leave it in permanently shut position,but won't know if doors left open,
And have no interior lamps if using that door.
Or the fault you have now......
Might have been easier to just fix it.
Frag
Ford Technician
