12v socket on the heater control panel fuse ????
Postby andy_bck » Mon Apr 23, 2018 5:51 pm
I have a 2017 transit, the fuse box location does not resemble the manual ??? I am trying to locate the fuse (this seems to be impossible, been to our local dealers and even they cannot find it, getting fed up with this now, anyone got an answer (there is NO fuse box behind the glove box) they are located under a panel to the left of the steering wheel and another to the right and below the steering wheel, and a third with very few fuses in under the bonnet??? any help appreciated
andy_bck
Re: 12v socket on the heater control panel fuse ????
Postby Frag » Mon Apr 23, 2018 7:07 pm
Is your van a 2.0 ecoblue / panther,as the fuseboxes are different ?
There are extra pages in the correct handbook with this fusebox shown that aren't in the early book...
Frag
Ford Technician
Postby Mick M58 » Mon Apr 23, 2018 7:33 pm
I drive a 14 plate mk8 350 rear wheel drive,same fuse blew on mine and it’s located in fuse box to left of steering column,3rd blue fuse down on right hand side 46 or47.Fuse is called a J case low profile fuse it cost me £4.99 at local auto shop,cheaper ones are on eBay.Not the best of fuses to get out.
Mick M58
Postby andy_bck » Mon Apr 23, 2018 8:26 pm
I am not sure how can I tell?
andy_bck
Postby Frag » Mon Apr 23, 2018 8:34 pm
Do you have a smaller blue filler neck in with the fuel filler housing?
Have to put ad-blue in it as well as fuel ?
Frag
Ford Technician
Postby andy_bck » Mon Apr 23, 2018 8:47 pm
Thanks for your replies, and yes we have the add blue filler
andy_bck
Postby Frag » Mon Apr 23, 2018 9:08 pm
Sounds like you have the wrong handbook then....
The earlier level one,later includes both types of fusebox.
I'll see if I can find the fuse you need.
Frag
Ford Technician
Postby andy_bck » Mon Apr 23, 2018 9:32 pm
Thank you Frag, your help is much appreciated, even our local dealer dont have a clue
andy_bck
Postby Frag » Mon Apr 23, 2018 9:43 pm
If it's the fuse layout I believe it should be,
The fusebox infront of your left leg,bottom rightmost corner should have 2 blue 20A case fuses,
F13 and F14.
I think one of these is your problem,you may just be able to see looking through its clear top which has blown
Frag
Ford Technician
Postby Frag » Mon Apr 23, 2018 9:45 pm
Or swap them around and see if the power socket near heater works and dash top tray one then doesn't .... :idea:
Frag
Ford Technician
Postby andy_bck » Mon Apr 23, 2018 9:52 pm
Thats fantastic Frag Thank you for your help, much appreciated
andy_bck
Postby andy_bck » Tue Apr 24, 2018 1:49 pm
UPDATE!!
Thanks Frag, that sorted it, you correct, the two fuses described are the two in question, problem now resolved!!!! MANY THANKS
andy_bck
