Front disc and pads l4 h3
Postby Fatsue87 » Thu May 03, 2018 10:29 pm
Does anyone on here know if the front disc has to be forced off the bearing I can’t find any info on the net cheers guys :D
Fatsue87
Re: Front disc and pads l4 h3
Postby Frag » Fri May 04, 2018 11:55 pm
No,either put the full hub on the floor and hit the disc,
Or,drop the hub and disc squarely from a few inches and disc will fall off the hub.
Frag
Ford Technician
Postby Fatsue87 » Sat May 05, 2018 7:03 am
That don’t sound bad so it must be different from the mk7 ford wanted 475 for disc and pads on the front they must be mad lol cheers il have a go
Fatsue87
Postby Frag » Sun May 06, 2018 2:50 pm
The hub and disc,come out of knuckle easier too I've found than mk7's.
Just make sure the holes for torx bolts into knuckle are clear on rebuild,as they aren't open at the back any more,you don't want any crap in them when refitting bearing bolts.
Oh,and it might be wise to replace the disc to hub bolts,we fit new ones,and quite often the old ones will snap with airgun before coming out,not an issue if you have new and are replacing the discs.
Frag
Ford Technician
Postby Fatsue87 » Wed May 09, 2018 8:33 pm
Thank you sorry sounds an easy job soon get it done
Fatsue87
