Mk8 transit rear hub seals replacing
Postby Lee1970 » Fri Jun 01, 2018 7:16 pm
Hi all I have a mk8 transit tipper, twin wheel base & need to replace the rear hub seals.
Have removed half shafts, but never before seen the hub nuts that are fitted?
Can anyone tell me how you adjust them ?
Any help would be great
Lee1970
Re: Mk8 transit rear hub seals replacing
Postby p2thed » Sat Jun 02, 2018 7:55 pm
Use Special Service Tool: 205-1007 (a must have to do it properly)
Torque: hub nut
Stage 1: 88 Nm
Stage 2:
Loosen 180°
turn hub 15 times then
Torque: 30 Nm
p2thed
