I’ve been told that the anti stall on the mk8 cannot be switched off even by ford dealers I had a look at the clutch pedal and it has two switch’s one with a plunger at the bottom of pedal travel which turns off the high tickover when the van is in gear the outher switch when disconnected will not let the van start and probably stop the cruise control working as well I have started van up and then unplugged it and van does not rev up when put in gear now I was thinking is there a switch on the gear linkage or gear box that I could unplugged to to stop it reving up when put in gear or is there a fuse or relay I could remove to turn the anti stall off without effecting any outher system on the van or can the anti stall revs be adjusted lower
