P2463, P246C Fault Codes And Limp Mode?
Postby Inked » Sun Aug 12, 2018 11:08 pm
Hi guys
I'm trying to fix a 2015 transit (engine code: CYR5) that has error codes P246C and P246C and is in limp mode.
I've tried doing a forced regen but for some strange reason none of my software gives me the option for this vehicle (it does for every other vehicle I've needed to regen).
I can clear the fault codes but they come straight back even without the engine being run.
Also if I do clear the fault codes while driving I get the full power back (comes out of limp mode) but this only lasts until the revs settle then it goes back into limp mode.
Any ideas ?
Inked
Re: P2463, P246C Fault Codes And Limp Mode?
Postby Inked » Mon Aug 13, 2018 1:16 am
I'm guessing this is more of an electrical fault rather than actually a blocked dpf filter as the fault comes back even before I start the engine so the ECU wouldn't know the dpf was blocked
Inked
Postby Altransit » Tue Aug 14, 2018 8:20 pm
:idea: Maybe one of the DPF sensors, or the wiring to the sensors :?
