Mk8 transit turn over like has no compression
Postby Tptransit » Wed Jun 15, 2022 8:56 pm
Hi I have a transit mk8 on a 2017 2.0 eco blue
I went out to move it start ok move Forward and engine cut it tried to restart sounded like had no compression Like the wet belt had snap
Stripped engine down to found that the belt was all fine and all it time took the head off pistons are all fine hydraulic lifters are all fine put it all back together. When starting it up after putting back together it started for 5 seconds and cut out and it sound like it has no compression
Can any one help
Tptransit
Re: Mk8 transit turn over like has no compression
Postby Johny200 » Mon Mar 04, 2024 9:40 pm
Hi mate was reading your post about low compression I have got exactly the same on my custom, has anyone posted back to you with any likely causes. Thanks john
Johny200
Postby Daddypoppet » Thu Apr 11, 2024 8:53 pm
I have the same issue same year van on 40000 new belt last year and exactly the same scenario.
Daddypoppet
Postby Altransit » Fri Apr 12, 2024 9:13 pm
Frag wrote:Have a read of this
viewtopic.php?f=64&t=226863
