Mk8 battery size
Mk8 battery size
Postby Rabfinn » Wed Mar 13, 2024 12:45 am
Hiya, I have a mk8 lwb 2016 2.2 tdci with the battery bolted in under the drivers seat, can anyone tell me the measurements of it to save undoing it then doing it up while I'm waiting on a battery to be delivered please, Thanks in advance
Mk8 Transit Trend 2.2 L3 H2
Rabfinn
Re: Mk8 battery size
Postby Altransit » Fri Mar 15, 2024 1:16 am
As you've had no response from someone in the know, I would hazard an educated guess that it will be the same as a Mk7:-
A single battery should be 315mm x 175mm x 175mm (110 battery e.g. Bosch S5)
Twin batteries, if fitted, may be a smaller size and capacity, but the larger batteries can still be fitted as the underseat space is the same.
Postby dumper » Fri Mar 15, 2024 7:08 am
Weighed mine in and would hat to take the seat swivel off to measure but this is what I fitted
Halfords EFB110 Start/Stop EFB 12V Car Battery 5 Year Guarantee
Dimensions (LxDxH): 317x175x175mm
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Postby Rabfinn » Sun Mar 24, 2024 7:36 am
Thanks very much guys I really appreciate it as I said I didn't want to unbolt my fivers seat if it could be avoided, luckily enough after a broken driver door loom broken wire causing a flat battery it was quickly repaired and I put a smart charger on under the bonnet and left it in repair mode and it's looking good, starting no problem. Again thanks very much to you both.
Rabfinn
