S60r wrote:I plan to put crossover inside the A pillar or as close as possible and run a short new cable from the low pass side back through the door gator and into the new speaker. I will then ditch the original speaker cables once it's all connected.
Trasher83 wrote:Any difference between the old Custom and the facelift model regarding speaker upgrades? Getting my faceliftmodel next week, and planning a little
TallPaul wrote:Trasher83 wrote:Any difference between the old Custom and the facelift model regarding speaker upgrades? Getting my faceliftmodel next week, and planning a little
The sound in my facelift (Sync 3) is definitely much better than my old Custom, not sure if its down to better soundproofing or if the actual speakers are better. I havent bothered to get the doortrims off to upgrade them.
S60r wrote:They will still be crap in the facelift..... they have likely amped the output up from the sync 2... probably pumped it up from the massive 2x10w to around 20watts or maybe higher :O
The oem speakers will still be utter crap though... they are across all marques. Paper cones, zero coil weightless rubbish, the cheapest they could find no doubt.
Marky M wrote:Did you already instal the amp. How did you removen the radio
Everything is already in place (rear speakers and amp, bud still have to connect it to the radio.
