Cable routing
Cable routing
Postby cycleguy » Sat May 26, 2018 10:51 pm
Hi there guys how hard is it to run some cables down the N/S to under the passengers seat And how are you guys with amplifiers getting 12v positive there also ? Thanks
cycleguy
Re: Cable routing
Postby loot » Sat May 26, 2018 11:16 pm
If i was doing it I'd use a 60A feed from the drivers seat base to feed the main live with a suitable contact switch, chassis ground and I would look at using a remote cable for switching.
That's how my power inverter is setup.
Assuming you mean audio amplifier then you'd want a radio on feed or simpler an ignition live feed.
There are a few variations to the above, you can feed the cable in the side of the van fairly simple.
07 350 170ps
Ids map here
loot
Re: Cable routing
Postby cycleguy » Sat May 26, 2018 11:47 pm
loot wrote:If i was doing it I'd use a 60A feed from the drivers seat base to feed the main live with a suitable contact switch, chassis ground and I would look at using a remote cable for switching.
Hi there loot thanks for your quick response I will take a look at the power in the seat base of the drivers seat will I need to remove the battery to work on this ? as for the remote turn on I am using a audio Control Lc2i which will be feed speaker inputs this unit has Auto sensing turn-on circuit and a remote out which I will run to trigger my amp and sound processor At present i have a bunch of cables all on the passengers side just behind the glovebox which need to find there way under the floor covering to the passengers seat base I'm not sure how hard this will be ? do you happen to know how to do this ? Cheers
cycleguy
Re: Cable routing
Postby loot » Sun May 27, 2018 10:51 am
You can work on the live fused feeds at the seat base without removing the battery but just be careful that you don't ground them or you'll blow their respective fuses.
I'm not 100% sure about cab floor cable routing but if it is similar to the mk7 then it goes from drivers seat to bcm/glove box area via the floor.
It may show you what you need if you go to www.etis.ford and put your vehicle vin in and download bemm transit custom 2012.75 or whatever you need.
07 350 170ps
Ids map here
loot
Re: Cable routing
Postby cycleguy » Sun May 27, 2018 1:22 pm
loot wrote:You can work on the live fused feeds at the seat base without removing the battery but just be careful that you don't ground them or you'll blow their respective fuses.
It may show you what you need if you go to http://www.etis.ford and put your vehicle vin in and download bemm transit custom 2012.75 or whatever you need.
I have my speaker cables in place now just doing to battery feed so question is will i have any problems if I disconnect the battery and reconnect when I'm done ?
cycleguy
Re: Cable routing
Postby cycleguy » Sun May 27, 2018 2:57 pm
All sorted thanks for the pointers Guys
cycleguy
Re: Cable routing
Postby loot » Sun May 27, 2018 3:02 pm
I'd avoid that if possible.
Wire everything up for the amp but remove its opp l blade fuse that is usually built in and wire the main live cable to the seat last, it'll be a 10mm nut so the cable wants to be an eye terminal. Key out of the ignition too.
As long as you don't cause sparks by being careless you'll be ok.
I don't know if the radio etc will lose a code on these like the mk7 did but I wouldn't want to chance it.
What amp is it mate?
07 350 170ps
Ids map here
loot
Re: Cable routing
Postby cycleguy » Mon May 28, 2018 8:42 am
Couple of pictures of what I’ve been up to
cycleguy
Re: Cable routing
Postby loot » Mon May 28, 2018 9:28 am
8)
07 350 170ps
Ids map here
loot
Return to Transit Custom
