Temperature sensor
Temperature sensor
Postby Veki007 » Fri Jun 22, 2018 1:29 pm
Hi guys does someone knows where i can find sensor that mesaure outside temperature as mine is showing 13° .I had a look but i can not find where it is so i can replace it inside or under bonnet?Many thanks.
Sent from my SM-G950F using Tapatalk
Veki007
Re: Temperature sensor
Postby Veki007 » Mon Jun 25, 2018 1:49 pm
Anybody?i have check everything on etis but it doesn't say where it is
Sent from my SM-G935F using Tapatalk
Veki007
Postby Nederbelg » Mon Jun 25, 2018 7:07 pm
I would guess it's somewhere low behind de Bumper/ Grille. It's there in most cars.
Gr Nederbelg
Nederbelg
Postby Veki007 » Mon Jun 25, 2018 7:46 pm
Nederbelg wrote:I would guess it's somewhere low behind de Bumper/ Grille. It's there in most cars.
Gr Nederbelg
Thanks but no luck i have pulled out complete grill and there is nothing unless im blind.I have called Ford and they want £100 for a part plus fitting at least 110(one hour ) and they do not want to say where it is but tbh i do not want to spend £200 for a that small thing sounds so expensive.
Veki007
Postby Nederbelg » Mon Jun 25, 2018 8:19 pm
In some cars it's in the wing mirror???
Gr Nederbelg
Nederbelg
Postby p2thed » Mon Jun 25, 2018 10:10 pm
its tucked up behind the front bumper,black connector 2pins
p2thed
Postby Veki007 » Mon Jun 25, 2018 11:04 pm
p2thed wrote:its tucked up behind the front bumper,black connector 2pins
Thanks tomorrow i will dismantle whole bumper to see.Many thanks
Veki007
Postby Veki007 » Tue Jun 26, 2018 10:36 am
I have found it thanks for a gelp i had to see if there is a problems with wires or something like that as few days back it came back to life so it was worth of cehcking so today i have unplugged and plugged back just for it to show -40° so it defenetley needs new one but at least i do not have pay for them to install it.Many thanks everybody that has helped.Image
Veki007
Return to Transit Custom
