belly wrote:I've only seen pictures but I reckon it bolts to the rack mounting points and folds into the factory roof ribs, I doubt they'd produce a different roof just for the rack option (could be wrong) so wouldve thought you can unbolt it Put bolts back in the mounting holes with a touch of sealant on the thread or you could end up with leaks !
Could you post some close piccies of the rack system please
warrenn wrote:belly wrote:I've only seen pictures but I reckon it bolts to the rack mounting points and folds into the factory roof ribs, I doubt they'd produce a different roof just for the rack option (could be wrong) so wouldve thought you can unbolt it Put bolts back in the mounting holes with a touch of sealant on the thread or you could end up with leaks !
When you see it you'll probably leave it on, it's quite impressive but very simple. Could be handy one day?
I didn't spec it but glad it came fitted to my dciv.
Warren
belly wrote:Thanks Warren It does look very neat and as I've said it does look like it can be removed or added IMHO I don't think it would be man enough for people who use there racks day in day out but the odd off/on with a ladder or materials etc then it's a very handy system
Rapidcool wrote:Thanks for the close up pics,do you get any wind noise from yours warren?
Rich
