yasser wrote:loot wrote:I haven't read all 6 pages, i saw the video clip, i never filled my van up but every time i put fuel in it dribbles down the usual place, I've tried waiting and wiggling and twisting the pump handle but it still does it
Probably creating a bubble or something?
There's no wiggling involved unless thats just you. Put the nozzle in, let the nozzle rest (so handle down and hole end up) in the filler, don't hold it up. Squeeze for fuel, let it click off, squeeze again for second click off and then leave for ten seconds before you pull out gently. It does work, i was always used to getting the last drop into the tank but the custom doesn't like it. just squeeze to 2 clicks only and thats it. also waiting the ten seconds as well as a lot of the fuel that comes out is from the pipe so pull out slowly
My initial try was the normal every vehicle I've owned fuel, finish, 2 seconds, quick wiggle then slowly remove.
That didn't work, so each time i tried it got more elaborate, in the end me hopping round the forecourt patting my head and rubbing my belly just seemed like overkill
I'll try waiting 10 seconds as you suggest but it's a bit hard when you've got birds waiting
Bloody capless, i bet it is because there's no open hole.
56 350 2.2 130ps mk7 with 2 side doors
65 290 2.2 125ps custom with 2 side doors
Ids v86 licence + v86.04 update + xprog
hereIds map
here
