ross1098 wrote:Also like the way the cornering lights both come on when selecting reverse gear. Gives you a lot more of a wider visibility when reversing. Well thought out.
Tran59 wrote:ross1098 wrote:Also like the way the cornering lights both come on when selecting reverse gear. Gives you a lot more of a wider visibility when reversing. Well thought out.
I didn't know they did that. Sounds good, though I am struggling to see what the purpose is when you're going backwards...
Tran59 wrote:Mike wrote:Yep, can't have yellow drl's, looks like a base spec Audi.
Exactly. Not a good look, especially on a Sport
Mike wrote:The main beam/drl bulb is an H15 (dual filament), so no upgraded bulbs are available
