Knackered drivers door - beware when opening them!!!
Postby hoggyf » Thu Feb 13, 2014 11:19 am
The drivers door last night was about half open when my hand slipped off the handle, I was parked half on the kerb so the van tilted, the door fell open and once closed has moved and wont open now, garage thinks its new hinges and a check strap and Ford are suggesting its not under warranty!!!
Surely the check strap should be capable of holding and stopping such a big heavy door??
Anyone else experienced this??
hoggyf
Re: Knackered drivers door - beware when opening them!!!
Postby Mike » Thu Feb 13, 2014 11:23 am
Not yet, but it's taking me a while to get used to the door handle being in the door panel rather than on top of it as it was on the Mk6 & 7.
Mike
Wind up merchant!
Postby yasser » Thu Feb 13, 2014 1:03 pm
Mike wrote:Not yet, but it's taking me a while to get used to the door handle being in the door panel rather than on top of it as it was on the Mk6 & 7.
And I thought I was the only one!
310 DCiV L2 Limited 155
yasser
Postby Alar » Thu Feb 13, 2014 1:06 pm
No, your not, have grabbed the top panel for many times now :D
125ps 310LWB Trend Powerty Edition
Alar
Postby John Johnson » Thu Feb 13, 2014 1:48 pm
Was a bit odd early on , they chip easy too ( the paint )
John Johnson
Postby yasser » Thu Feb 13, 2014 4:03 pm
John Johnson wrote:Was a bit odd early on , they chip easy too ( the paint )
And I thought you meant your nail polish
yasser
Postby John Johnson » Thu Feb 13, 2014 6:20 pm
My nail polish is fine sweety .... A lady wears gloves
John Johnson
Postby limitedblack » Thu Feb 13, 2014 6:29 pm
Is that a selfie ?
Happy Easter
limitedblack
Postby John Johnson » Thu Feb 13, 2014 6:35 pm
Lol cheeky coont
John Johnson
Postby Tran59 » Fri Feb 14, 2014 10:03 am
Similar experience a few weeks back. A strong gust of wind wrenched the door out of my hand and it was flung back on its hinges. It made a terrible noise and I was sure something had broken, but I think I got away with it, no visible damage.
The best mods are the ones you don't see
Tran59
Postby hoggyf » Fri Feb 14, 2014 10:15 am
Had another look this morning and noticed that compared to a mk 7 the doors opens a little wider and where the check strap is bolted to the shell you can see the shell flexing when the door is at full stretch. I was always conscious of this as a potential problem because of the size and weight of the doors. To my mind its a design fault, I think the shell or check strap bracket needs strengthening.
hoggyf
Postby Mike » Fri Feb 14, 2014 10:26 am
MK7 flexes around the hinges and check strap too. Can you post up a pic of the damage to the check strap area?
Mike
Wind up merchant!
Postby hoggyf » Sat Feb 15, 2014 12:32 pm
I will do on tues/wed if possible, its in the body shop then, the door will only open 6" so I'm having to use the passenger door at the minute
hoggyf
Postby hoggyf » Thu Feb 20, 2014 10:24 pm
Went in on wed morning for the day to then get a phone call in the afternoon to say they've had to order hinges from Germany, (3 days delivery) and if that doesn't work it will need a new door! Not bloody happy!!!
one of the first things I thought when I got the van, was to be careful with the door, as it was so heavy and opens so wide. I can only open the door half way while sitting in the drivers seat before stepping down and allowing it to go fully open.
Ford better get there hand in there pocket to cover this
hoggyf
Postby dan_robinson » Thu Feb 20, 2014 10:36 pm
Builder I work with has bought 3 or 4 Customs, and one of them went in for this problem last week.
No arguments from Ford - it was covered under warranty.
Builder was not going to tell the guy that drives it for a bit to scare him :lol: Told him it needed a new door and it was coming out of his wages. G1t. :D
dan_robinson
Return to Transit Custom
Users browsing this forum: dwlawson
