loot wrote:I got told today that fords fix on later vans is that they have adjusted the wings and bonnet forward so the door/wing gap is bigger, i have seen them with a gap and initially thought it was 1 that had been repaired.
Mike wrote:loot wrote:I got told today that fords fix on later vans is that they have adjusted the wings and bonnet forward so the door/wing gap is bigger, i have seen them with a gap and initially thought it was 1 that had been repaired.
The check straps are shorter, so the doors don't open as far. So they have less time to build up momentum.
abar121 wrote:Mike wrote:loot wrote:I got told today that fords fix on later vans is that they have adjusted the wings and bonnet forward so the door/wing gap is bigger, i have seen them with a gap and initially thought it was 1 that had been repaired.
Can we buy the check straps and fit them ourselves?
Mike wrote:abar121 wrote:Mike wrote:The check straps are shorter, so the doors don't open as far. So they have less time to build up momentum.
Almost certainly, you'll probably need the vin from a current van so the parts guy can order the correct ones.
abar121 wrote:Mike wrote:abar121 wrote:[quote="Mike"]The check straps are shorter, so the doors don't open as far. So they have less time to build up momentum.
loot wrote:I tried mine but it said not found
Can someone with a custom that knows it has older straps take a measurement of the door fully open? Also a pic of where they have measured, it'll help ppl i think.
Also has anyone thought about modifying the straps so they have limited movement? Why buy new ones?
