moley551 wrote:Fitted a new dash camera....thanks to Yasser...looks like you need to protect yourself from rozzas rather than the uninsured.
loot wrote:Altransit wrote:loot wrote:Nearly punched the satnav to death today there's a space bar somewhere but it is not somewhere obvious
Bloody siemens or whichever pleb made it
Don't you press nought twice, or summink similar Or just use Waze and shout at it
I shouted at mine like fook but it didn't respond
There's nothing on the text and number page, I'll try symbols tomorrow and have a good look but it isn't obvious at all, it should be an icon on all available pages of input ffs.
Read online that it is a lying down bracket symbol but i would have tried that if i saw it
It isn't a direction button as they navigate around.
I also have a setting called tolerance which basically shows all keys rather than only highlighting the predicted keys.
Still no obvious space button.
Problem is that you only really use sat nav to get to somewhere and invariably when you are in a hurry
Yes buddy, I drive it like a grandad though!!aerial copters wrote:Kent Discos wrote:#foamfriday
Tried some snow foam from the first time today and gave her an exterior clean with it
Sent from my SM-G955F using Tapatalk
Hi, do you find the 130 quick enough, cant make mind up whether to go for that or the 170
bigjohnthomas wrote::D upgraded mine too
Found a ford badge in a hedge
Cool
