What did you do to your Custom today?
Re: What did you do to your Custom today?
Postby roughtech » Sat May 06, 2017 8:33 am
bigjohnthomas wrote:I think they are escaping from the engine management system :?
And Ford are still refusing to admit there is a problem :x :x
In the first image I just thought your missus took a picture of you working on the van... but I see from your second image that may not be the case ))
Sent from my SM-G900F using Tapatalk
roughtech
Postby bigjohnthomas » Sat May 06, 2017 11:50 am
:lol:
I think those little French b*stards have f*** the van up :x
Driving down the motorway this morning and all of sudden it slows down to 60 and won't go any faster
Had to PULL OFF on to the HARD shoulder re start it and its not done it since
Have to drive home yet though
Bloody ford
Bloody frenchies
bigjohnthomas
Postby roughtech » Tue May 09, 2017 7:11 am
They did the warranty work on Friday and I got the oil and filter done while it was in. Noticed oil on the ground yesterday and when I popped the bonnet one of the technical experts hadn't put the dipstick in properly. Pullies, belts, electrics, all soaked. When I rang they asked me to drive it over but when I suggested it may not be a good idea to drive an oil soaked engine which may be internally low on oil...thankfully they sent someone over.
roughtech
Postby bigjohnthomas » Tue May 09, 2017 7:21 am
Bloody ford :D
Oil came all the way up the dipstick tube? :o
bigjohnthomas
Postby bigjohnthomas » Tue May 09, 2017 10:00 am
Just Dropped it off at the transit hospital :(
You know the one next to dfds
Bloody limp mode again :x
Hope I parked it far enough away from those trampy mk7s
Don't want it catching bugs off them eueeechk
dignitas
bigjohnthomas
Postby roughtech » Tue May 09, 2017 10:37 am
bigjohnthomas wrote:Bloody ford :D
Yes..sprayed everything. They did everything except fit the new dipstick as it hadn't come in yet. So when I saw it yesterday about four inches out of its housing I tried to put it back but it didn't seem to fit so I just presumed it was too long (as the new one is apparently shorter-2ltrs less oil).
My first thought was if they put in the right amount of oil why didn't they just cut it shorter till the new one arrived . When the mechanic just pushed it home it was obvious that it was just a nice tight fit so had just been left loose!!!
roughtech
Postby loot » Tue May 09, 2017 11:22 am
Why wouldn't the old dip stick fit?
Ids map here
loot
Postby bigjohnthomas » Tue May 09, 2017 11:25 am
Plenty of back pressure to blow it up there then ?
I am going to try mine after
bigjohnthomas
Postby loot » Tue May 09, 2017 11:32 am
All sounds like a bodge up to me, we've always been told that the pull level on the dip stick shouldn't exceed maximum, OK there's a few mm safety margin but how much more is safe? You'd think that does would change the sump to a bigger 1?
2litres of oil and tin snip the dipstick shorter??
Sounds like a Heath Robinson Lash up to me :mrgreen:
:lol:
Ids map here
loot
Postby roughtech » Tue May 09, 2017 11:39 am
loot wrote:All sounds like a bodge up to me, we've always been told that the pull level on the dip stick shouldn't exceed maximum, OK there's a few mm safety margin but how much more is safe? You'd think that does would change the sump to a bigger 1?
I thought they changed the holder for the dipstick or the sump plate to accommodate the new dipstick but it was just tight and I didn't want to force it. It was just a tight fit and not put back properly. The new dipstick is just longer to suit the reduced oil level
roughtech
Postby loot » Tue May 09, 2017 1:02 pm
Eh? So they've put less oil in? That's even worse isn't it? The mk7 ones they put bigger sump on to increase service internals didn't they?.
Smells fishy to me now :lol:
Ids map here
loot
Postby bigjohnthomas » Tue May 09, 2017 1:07 pm
The oils only in for 30000 miles so it won't need much :lol:
They haven't rung to say Billy's ready yet :x
I am near there now probably see them driving past in it in a minute going to get chips :x
Bloody ford
bigjohnthomas
Postby loot » Tue May 09, 2017 1:15 pm
bigjohnthomas wrote:The oils only in for 30000 miles so it won't need much :lol:
Bloody ford
30000 miles is way too much, that's from my house to Madame tussauds in London then to your house then back to my house give or take and the miles i do it would take 6 years :? I make a point of not going over 4 years on account that engines tend to frown upon it and decide to retire from service forth with :oops:
Ids map here
loot
Postby bigjohnthomas » Tue May 09, 2017 2:25 pm
Well if the oil scientists say it will be good for 30k :)
bigjohnthomas
Postby roughtech » Tue May 09, 2017 2:29 pm
bigjohnthomas wrote:Well if the oil scientists say it will be good for 30k :)
Maybe it is best to leave them to global warming and just change the oil every year when it's in for its check )
roughtech
Return to Transit Custom
