What did you do to your Custom today?
Re: What did you do to your Custom today?
Postby bigjohnthomas » Wed Jan 31, 2018 2:15 pm
Pussie :lol: :lol:
bigjohnthomas
Postby Gazbolok » Wed Jan 31, 2018 2:20 pm
wanted to keep the back as a van; going to install a camera to capture the little scrotes face when he smashed it to break in only to discover the airs gone all solid like metal behind it
Gazbolok
Postby Dywlc » Tue Feb 13, 2018 4:53 pm
I tried to start it but the battery was flat. Thats what I did to my custom today :(
Yesterday I took the drivers seat out to fit a second battery and an inverter to give me 240V in the cab. I didn't have all the bits I needed so I left the seat in the back of the van overnight. I put the plastic cover back on the battery so nothing would fall on the terminals and start a fire. Came to it today and the front indictors were flashin very dimly. The ones on the mirrors the same but not the back ones. The van wouldn't unlock from the remote key so I had to unlock it using the key in the door. Put a voltmeter on the battery and it's registering 5 volts. Put a battery charger on the battery and it charged for a few seconds then all the lights on the battery charger, showing the state of charge, went out. I've left it charging but no lights on the charger.
Does the driver's seat have to be in place? Does leaving it disconnected mess up some of the gadgets, computers or magic spells boxes?
It's 11 months old yet and has only sone 2300 (yes 2300) miles. I started it at the beginning of this month after it being stored since beginning of September 2017. It started first time then.
PUZZLED!!
Dywlc
Postby AusTansit » Wed Feb 21, 2018 1:36 am
Made some shelves
AusTansit
Postby cycleguy » Sat Feb 24, 2018 10:37 am
Nice job good use of the space
cycleguy
Postby loot » Fri Mar 02, 2018 2:14 pm
Cleaned it :-)
Anyone got a fusebox lid for me? :mrgreen:
Ids map here
loot
Postby bigjohnthomas » Fri Mar 02, 2018 9:47 pm
Looks a bit scruffy in there :lol:
This bloody eco meter .. 36mpg best ever for a 155
But I get no petals for speed :x
Its those bloody autobahns :P
bigjohnthomas
Postby Transitcustomguy » Mon Mar 12, 2018 11:08 pm
Zombie chasing lights
Transitcustomguy
Postby bigjohnthomas » Fri Mar 23, 2018 1:02 pm
:lol:
Hankook ventus 6mm left 32 turnips :)
A dunlop and a michelin primacy both with 6mm left on their way 32turnips each
Different ditchfinder on each corner allcock :P
Bloody stupid 18" tyre size
bigjohnthomas
Postby loot » Fri Mar 23, 2018 1:40 pm
Think you've got problems I think my van is senile :?
Can ya tell what it is yit?
:P
Ids map here
loot
Postby bigjohnthomas » Fri Mar 23, 2018 8:07 pm
Its waving :P
Mines off the the kc buildings in stoneleigh tomorrow
Lucky that new tyre came today
Tyre wear a tad uneven :lol:
Front drivers side the bald flat bits on the inside
Now then ,is that just because its a sh*t tyre (landsail) and not very round its worn like that ?
bigjohnthomas
Postby bigjohnthomas » Fri Mar 23, 2018 8:08 pm
That's the good side
bigjohnthomas
Postby loot » Fri Mar 23, 2018 9:34 pm
Maybe, inside or outside?
You do roundabouts the same way all the time so technically you should get passenger outside scrub first on a new set of tyres.
Cheaper tyres don't have as much metal braiding near the corners so they flex more and get more scrubbing especially if you drive like dukes of hazard :lol:
El tyro? :P
Ids map here
loot
Postby loot » Fri Mar 30, 2018 2:24 pm
Driving like I have a coffin in the back :shock:
Suckit? :P
Ids map here
loot
Postby bigjohnthomas » Fri Mar 30, 2018 7:02 pm
You need some diesel loot :lol: put 60 bloody turnips worth in mine today :(
fixed the back door hinges going stiff with some whall clipper oil
All good perfect now
bigjohnthomas
Return to Transit Custom
Users browsing this forum: SidTSloth
