S60r wrote:I get a slight "miss" if you are on over run and then lightly come back on throttle.... It feels like a misfire, but I can make it happen at will. I thought it did this when it was performing a DPF regen but it does it quite frequently.
It isn't causing any issues, but yes its annoying. I don't think its a fault in fuelling or the map as mine is remapped and it still does it. I'm convinced it is when regens occur..... Mine would regenerate often as I do local journeys and never does it see a motorway.
If you are getting limp mode that is something totally different and is a clear fault.
mavericktc wrote:S60r wrote:I get a slight "miss" if you are on over run and then lightly come back on throttle.... It feels like a misfire, but I can make it happen at will. I thought it did this when it was performing a DPF regen but it does it quite frequently.
Have the exact same problem.
My van is produced late may 2016.
S60r wrote:mavericktc wrote:S60r wrote:I get a slight "miss" if you are on over run and then lightly come back on throttle.... It feels like a misfire, but I can make it happen at will. I thought it did this when it was performing a DPF regen but it does it quite frequently.
mine is January 2016
S60r wrote:No.... a remapped 125 2.2.
I'm convinced its a software issue that is consistent across all models and definitely DPF regen related. I see this issue reported on a couple of forums across all models.
I will delete the DPF and alter the map to suit one day, and I will wager the problem will disappear once the van doesn't regenerate the DPF.....but I won't do that until the DPF needs replacing so a few years down the road hopefully.
Its a fault of sorts but i'm sure its nothing to worry about. it is too common an issue to be of concern.
