LED lights, nice, but the the hell do you switch them on/off
Re: LED lights, nice, but the the hell do you switch them on
Postby david.pearce » Tue Jul 08, 2014 4:18 pm
we have just purchased a limited lwb custom, when you unlock the vehicle the lights in the load bay come on, does anyone know if you can manually switch them off, the courtesy light switch in the cab does not seem to have any effect on the load bay lights.
david.pearce
Postby peninsulalawncare » Sun Jul 13, 2014 9:24 pm
yasser wrote:I bought a little switch from maplins and connected it to the feeds of my LEDs. As the switch has double terminals I could do both LED independently from the one switch, ran the wires down the corner pillar to one of the holes that is already there. This is the switch I bought but Black only without light indicator. All it will do is turn the LEDs off and on when they are supposed to be on. It will not give you independent control of the LEDs.
http://www.maplin.co.uk/p/slim-rocker-s ... -red-ml79l
This is the switch is situ.
Yasser, how difficult was it to wire this in bearing in mind I have very little electrical knowledge, cheers.
peninsulalawncare
Postby yasser » Sun Jul 13, 2014 10:36 pm
very simply. both interior lights have their own feed and return, that is, the feed does not go from one and then to the other. All you have to do is take the light out, disconnect the feed wire, get a length of suitable cable with a male spade connector and plug it into the feed female spade connector, route the cable to where you want it and connect to the switch, Then take another length of cable and attach to the load terminal of the switch and then route back to the light ( obviously these steps would be done with suitable twin core cable), Connect a female spade connector onto the cable and then attach to the light. All you have effectively done is put in an "inline switch" Then just repeat the same for the other light. The switch I put the link for has a double pole, so it has 4 terminals. 2 feed and 2 load terminals so you can run both lights from the 1 switch but keep them separate.
Hope that makes sense !
310 DCiV L2 Limited 155
yasser
Postby peninsulalawncare » Mon Jul 14, 2014 9:20 pm
yasser wrote:very simply. both interior lights have their own feed and return, that is, the feed does not go from one and then to the other. All you have to do is take the light out, disconnect the feed wire, get a length of suitable cable with a male spade connector and plug it into the feed female spade connector, route the cable to where you want it and connect to the switch, Then take another length of cable and attach to the load terminal of the switch and then route back to the light ( obviously these steps would be done with suitable twin core cable), Connect a female spade connector onto the cable and then attach to the light. All you have effectively done is put in an "inline switch" Then just repeat the same for the other light. The switch I put the link for has a double pole, so it has 4 terminals. 2 feed and 2 load terminals so you can run both lights from the 1 switch but keep them separate.
Cheers Yasser, ye pretty much makes sense, how easy is it to get to all the parts of the process you list above?. You say both the lights, I have four sets in mine? two at the front and two at the back, or is that what you mean by both, front and back?,
peninsulalawncare
Postby yasser » Mon Jul 14, 2014 9:29 pm
I Have a DCiV so I only have the 2 rear lights. If you have 4 lights you will have to have 2 switches or find the main feed and switch from there.
yasser
Postby jasonx » Mon Jul 14, 2014 9:34 pm
I'm still trying to decipher some wiring diagrams,as I would like to disable my lights some times.
I noticed this in the BEM manual ? I need to investigate more.
jasonx
Postby ake » Tue Jul 15, 2014 7:16 am
jasonx wrote:I'm still trying to decipher some wiring diagrams,as I would like to disable my lights some times.
Don't over complicate things, just do as yasser has posted above
Postby peninsulalawncare » Thu Jul 17, 2014 8:58 am
yasser wrote:I Have a DCiV so I only have the 2 rear lights. If you have 4 lights you will have to have 2 switches or find the main feed and switch from there.
Ye, it would be nice to find the main feed and be able to just put one switch in???
peninsulalawncare
Postby Treespotter » Mon Sep 29, 2014 9:16 am
GOT IT! I FOUND THE MAIN SWITCH... Sort of.
In the drivers cabin there are two over head light units. Both work on the doors. But, the one next to your head has the magic switch. Switching the middle switch to the 0 position leaves the back compartment dark when entering the car via the front door... At least after twenty seconds!
Treespotter
Postby Treespotter » Mon Sep 29, 2014 4:59 pm
I don't think this is the solution is it.
Treespotter
Postby richbee » Thu May 25, 2017 12:48 pm
Treespotter wrote:GOT IT! I FOUND THE MAIN SWITCH... Sort of.
So if you switch this switch to the off position, does it stop the rear LED lights from coming on when you open the doors???
richbee
Postby Treespotter » Thu May 25, 2017 12:50 pm
Have you read the last post?
Verstuurd vanaf mijn S30 met Tapatalk
Treespotter
Postby Treespotter » Thu May 25, 2017 12:53 pm
Read the post under the one you quoted...
Treespotter
Postby richbee » Fri May 26, 2017 12:16 pm
Treespotter wrote:Read the post under the one you quoted...
Yes, got you - ah well, was worth a try!
richbee
Postby Treespotter » Fri May 26, 2017 12:25 pm
It's a bummer Ford didn't opt for a dedicated switch in the back.
Wolter
Treespotter
Return to Transit Custom
