Custom rear speakers
Postby ojf10000 » Tue Sep 16, 2014 9:54 am
Hi guys, I have a transit custom limited and am wanting to install some rear speakers. I have removed the head unit and found there is rear speaker cables connected. Does anyone know where these run to? Presume they are left spare somewhere? If i can find will save me running new cables in.
On a separate note the front speakers, mids in door, tweeters on pillar. Does anyone know where the cable splits to each tweeter and mid speaker. One pair leaves head unit per side but can not find where the cable splits to door and pillar. Could do with finding to add a crossover which my new component speakers require. The standard speakers have built in filters so crossover will not be fitted as standard.
Ollie
ojf10000
Re: Custom rear speakers
Postby Chawnz » Wed Sep 17, 2014 7:31 am
I can't help but would like to know! I'm guessing sports maybe come with rear speakers as standard?
Chawnz
Postby ojf10000 » Wed Sep 17, 2014 11:54 am
Not sure about sport but think the toureno with rear seats has them! Fingers crossed someone will appear with an answer!
ojf10000
Postby Sparkeselectrical » Fri Sep 19, 2014 4:50 pm
I'd love to know too so I can fit them in rear of double cab
New 170 Limited 290 L1 DCiV
Sparkeselectrical
Postby BringTheRain » Sat Sep 20, 2014 7:18 am
I have been down this route, and the wires should run to the rear 1/4
The speakers need to be switched on with that IDS ford unit.
I was lead to believe that the rear speaker wont work other Bluetooth, sounds like total waffle. The guy who told me has done a few ford transit upgrades though (sub/amps and retain stereo)
BringTheRain
Postby ake » Sat Sep 20, 2014 8:07 am
BringTheRain wrote:I have been down this route, and the wires should run to the rear 1/4
The phone bluetooth only uses the front speakers, but streaming should use all if they are enabled in the BCM using ids
Postby ojf10000 » Sat Sep 20, 2014 2:57 pm
Ok thanks for that. So the rear speakers need enabling? I was told they would work but if i wanted to use the front/rear fader i would need that activating. Is it only ford who can do that?
Cheers
ojf10000
Postby ake » Sat Sep 20, 2014 3:35 pm
ojf10000 wrote:Ok thanks for that. So the rear speakers need enabling? I was told they would work but if i wanted to use the front/rear fader i would need that activating. Is it only ford who can do that?
Cheers
Anyone with ids. Where are you?
Postby ojf10000 » Sat Sep 20, 2014 4:40 pm
Im in york mate
ojf10000
Postby ake » Sat Sep 20, 2014 5:43 pm
I'm a bit far away , but there may be someone near you
Postby ojf10000 » Sat Sep 20, 2014 5:48 pm
No probs mate thanks for your help. Presume its the kind of thing my local ford dealer would charge a fortune for?!
ojf10000
Postby customal » Sat Sep 20, 2014 7:57 pm
[/quote]
Anyone with ids. Where are you?[/quote]
like this one ?
http://www.ebay.co.uk/itm/2014-New-FORD ... 9601&rt=nc
customal
Postby yasser » Sat Sep 20, 2014 8:06 pm
like this one ?
http://www.ebay.co.uk/itm/2014-New-FORD ... 9601&rt=nc[/quote]
Not sure if I'd like to plug that into my van, especially when it says its not 100% genuine.
310 DCiV L2 Limited 155
yasser
Postby ojf10000 » Sat Sep 20, 2014 8:15 pm
£200 is a bit out of my price league! :-p
ojf10000
Postby BringTheRain » Sat Sep 20, 2014 8:17 pm
Ahh thanks for that, makes perfect sense!!!
BringTheRain
Return to Transit Custom
