Eberspacher fitted to new Custom
Postby RussC73 » Tue Sep 16, 2014 8:28 pm
I fitted my recently purchased Eberspacher D2 auxiliary heater to my new custom, the job was fairly straight forward as the heater hit was complete with wiring looms, fuel lines and pump.
I purchased a little fuel tank which I bolted to the end of my racking.
Once I had located the best area to install the heater I cut out the required holes and bolted the heater to the floor under the passenger seat.
I then installed an adjustable vent outlet into the steal box section of the passenger seat as well as the air intake in the plastic side section.
The hot air hoses were split between the cab and the cargo area, an additional vent outlet was mounted into the bulkhead near the side loading door.
So now I can channel the hot air between can and rear... Cool!
The timer was then installed into the plastic side section of the passengers seat, this avoids having to drill the dash and mess about lifting the floor to lay cables.
Anyway here are some pictures, the exhaust and silencer will be wrapped in a heat resistant bandage just as soon as it's delivered.
RussC73
Re: Eberspacher fitted to new Custom
Postby Sparkeselectrical » Tue Sep 16, 2014 9:14 pm
Neat
New 170 Limited 290 L1 DCiV
Sparkeselectrical
Postby Dazgast280 » Tue Sep 16, 2014 11:50 pm
I want one!
Dazgast280
Postby RussC73 » Wed Sep 17, 2014 5:07 pm
Set the timer last night, cab and rear was lovely and warm even after just 10 mins this morning
Great bit of kit
RussC73
Postby Herts » Wed Sep 17, 2014 5:27 pm
Russ, you have done a fab job there.
How much was the D2, and where did you get the fuel tank from?
Andy
MK7 - 2.4 RWD/HR/LWB 3.5T 140HP (BIG BOYS TOY!)
Number 1 Emergency Call out Engineer!!!
http://www.hertsplumbinganddrainage.co.uk
Herts
Postby RussC73 » Wed Sep 17, 2014 8:59 pm
Hi Andy
http://www.ebay.co.uk/itm/181396976482
Purchased the D2 from a good seller on eBay, cost me around £500, also purchased the 60mm heater hose and the vents, the seller still selling quality refurb D2's on eBay.
http://www.ebay.co.uk/itm/151404152428
RussC73
Postby Herts » Wed Sep 17, 2014 9:19 pm
Many thanks Russ, It's now in my watching. Just have to raid the piggy bank.........again!
Andy
Herts
Postby RussC73 » Sat Sep 20, 2014 11:56 pm
Andy, you won't regret it... Camped out this weekend in the van and the heater came in very handy!
RussC73
Postby bluebottle » Thu Nov 30, 2017 4:18 pm
Bit of a zombie, but I just wondered if you were happy with your setup still, Russ? A friend of mine is convinced you should put the heater outside, but the destructions tell me otherwise.. Also, mine came with a kit for plumbing straight into the fuel tank, to the secondary outlet (which is a PITA because fuel tank must be dropped etc etc). I can't quite work out from your pic where you have that little fuel tank fitted? Are you still convinced a secondary tank is the best thing? Ta
bluebottle
Postby khould » Thu Nov 30, 2017 6:52 pm
I had one fitted to the underside f the van and Set it up direct into the fuel tank. This was fitted by a conversion company in Cornwall and works really well.
I do like the controller you have, do you know what the part no. is as I only have a very simple on and off with a turn knob to set the heating which you have to guess the temp as it dosent have a display
Your install looks good
khould
Postby vanvliet » Wed Jan 31, 2018 10:28 pm
The Wellhouse Eber is fitted underneath the van and seems to work well but I worry that over a long period of time it will be more likely to be affected by the elements /salt spray etc . The only mod I made was to fit an uprated marine silencer
Kiravan seem to be offering a very similar heater but at a much lower price than the Eber.
I too am interested in the timer as the standard fitting is simply on/off . I have not used the blown air only mode -lets hope we have a good summer to try it out!
vanvliet
Postby dumper » Thu Feb 01, 2018 3:41 am
Your mate is probably thinking about the D5W water heater that heats up the engine water system that BT had on some of the early transits some in engine bay and some under n/s/f step I have had my D3 under the bunk for the last 8 years with no problems at all if it had been under the van I think it would have been deed by now :D
Past camper vans
1986 mk3 2.5 di swb
1990 190 lwb 2.5 di
1998 100 lwb 2.5 di
2006 350 jumbo 135 tdci
dumper
Return to Transit Custom
