transit custom bonnet lock not releasing
Postby leethelocksmith » Sat Nov 22, 2014 6:32 pm
hi - i have a new shape transit custom and had it from new -(63)
i have a problem that the bonnet wont open - looked at manual and i am doing it right i.e key to left (hood should pop) then key to right and should release
but nothing is happening at all the key just turns left to right with no feed back at all....tried both keys nothing happens..
any advise or has any one else had this problem -- as a locksmith its quite embarrassing :oops: :oops: - but on the same token i am not an auto locksmith - i have tried airbagging the hood and trying to slip the catch - but to be honest i am not familiar with the system - i have even had a scope in there..
any advice would be appreciated
regards
lee
p.s
my van also sits at a 1000 - 1200 revs when idle does any one elses do that
leethelocksmith
Re: transit custom bonnet lock not releasing
Postby Treespotter » Sat Nov 22, 2014 7:26 pm
You're probably doing it correctly and there's probably something come loose but still I want to tell you the obvious.
Turn left and the bonnet pops up. Turn right and keep the key in that position and you can lift the bonnet.
Does that work?
Treespotter
Postby blue estate » Sat Nov 22, 2014 7:28 pm
They probably used the surplus mk2 focus bonnet locks as they have a habit of breaking :evil: I know it's happened to me
72plt MG 5 ev estate Battery car
blue estate
Postby leethelocksmith » Sat Nov 22, 2014 7:37 pm
Treespotter wrote:You're probably doing it correctly and there's probably something come loose but still I want to tell you the obvious.
Does that work?
no mate
but thanks for the help
leethelocksmith
Postby TallPaul » Sat Nov 22, 2014 8:52 pm
Have you tried pushing down on the bonnet whilst turning the key- this can release any tension on the catch and free it open. The fact that you've airbagged it to try and somehow force it open isnt going to help!!
TallPaul
Postby ianboustead » Sat Nov 22, 2014 9:37 pm
Had this same problem. The key turned but no resistance felt at all. It went back into dealer and they replaced the key lock assy. Big job they showed me the picture of the whole front of van off to replace it and then the time consuming job of setting up the new lock to work with existing key. You can just slip a short bit a wire in with a hook on and pull the cable just before the key lock if you need to be in. I had to do this for a few months.
ianboustead
Postby Alar » Sat Nov 22, 2014 10:00 pm
One may ask - what to you do under the bonnet so often? Even with bad wheather, the washer fluids last more than a month
125ps 310LWB Trend Powerty Edition
Alar
Postby Chawnz » Sat Nov 22, 2014 10:13 pm
Take it back!
Chawnz
Postby leethelocksmith » Sun Nov 23, 2014 11:18 am
Alar wrote:One may ask - what to you do under the bonnet so often? Even with bad wheather, the washer fluids last more than a month
Its For that exact reason buddy - low on washer fluid !!
leethelocksmith
Postby blue estate » Sun Nov 23, 2014 11:25 am
You are supposed to check oil water etc weekly :wink:
blue estate
Postby yasser » Sun Nov 23, 2014 11:46 am
I think as a professional driver you'll find that should be daily
310 DCiV L2 Limited 155
yasser
Postby blue estate » Sun Nov 23, 2014 12:12 pm
of course I do (scratches chin ) :wink:
blue estate
Postby ake » Thu Nov 27, 2014 7:05 pm
I do it every time a refuel ;)
Postby Krank_It » Fri Dec 19, 2014 8:29 pm
My bonnet release seems to have broken today. Can't believe there is no secondary option to open it. Went to local ford dealer and after they promptly finished bouncing on my bonnet saying "The catch is probably stuck" decides to book it in 8th of Jan yeh like I can wait around till then. Don't fancy having to drive around with a spare bottle of windscreen wash so I can splash the window every time it needs a clean ..... :evil:
Ah ha few phone calls later and different dealer and it in on Tues 9am as long as it does require replacement parts I'm sorted ... :P
Krank_It
Postby bluebottle » Mon Nov 21, 2016 6:27 pm
ianboustead wrote:Had this same problem. The key turned but no resistance felt at all. It went back into dealer and they replaced the key lock assy. Big job they showed me the picture of the whole front of van off to replace it and then the time consuming job of setting up the new lock to work with existing key. You can just slip a short bit a wire in with a hook on and pull the cable just before the key lock if you need to be in. I had to do this for a few months.
Ianbousted, can you describe this in more detail? Am on Spanish campsite with flat battery and bonnet lock has gone again..
bluebottle
Return to Transit Custom
