Ktm300excjohn wrote:This looks excellent yasser who done it mate ?
Trade windscreens in Carlisle. 01228 810018
RussC73 wrote:When i took delivery of my van i had the rear professionally ply lined, i am thinking about buying a kit off ebay (about £170) and first apply the foil/bubble insulation to the factory ply lining behind and then the carpet on the newly fitted ply lining.
Some people have advised not to pack out the areas behind the ply lining with loft insulation as it can hold moisture which can lead to corrosion.
Just my idea... if anyone else has any ideas?
bigbrush wrote:Hi,
Just done my high roof one, used kingspan on roof then cut plywood panels done in 3 sections, sides put wool insulation behind panels only loosely and then cut panels and stuck double foil to back and carpet to front folded over edges and screwed in place. and double bubble foil under plastic floor lining, i use it as work day van will take some pics tomz.
HandySparks wrote:I insulated and ply lined the roof of my Custom because my previous Transit dripped condensation in the winter:
The insulation is Thinsulate from 3M. The double sided sticky is just there to hold it up while I fitted the ply. Also stuffed some in the side panels and doors.
http://www.3mdirect.co.uk/sound-insulat ... 24m-1.html
Easy to work with, cuts with a pair of scissors, and not itchy.
stehanson wrote:HandySparks wrote:I insulated and ply lined the roof of my Custom because my previous Transit dripped condensation in the winter:
Interesting to read of this product as last time I used thermoliner after reading many posts about it on vw sites which given all the ribs on a connect roof was a nightmare to apply, should be easier on the new custom though as it's fairly flat on the roof areas, but yours would be easier still
Do you think you needed to ply over it or could you leave is as the finished roof??
ravin beef wrote:That 3m stuff looks the business!
Does it cut out a noticeable amount of road noise too?
Hi could you tell me who did your van as I need to get my van done and that's a cracking job?yasser wrote:
Unless you are good at it I found it easier to pay to get it done. Get it done professionally, you'll get a better finish. Don't forget, these boys are usually doing all day long. This cost me £500. Ply lined, Insulated and LED lights. It would have cost about £150-£200 for materials if I had done it my self plus the time. This way I dropped the van off for the day, picked it up and it was done.
