Advice on carpeting the rear...
Re: Advice on carpeting the rear...
Postby robbie.cee » Tue Dec 30, 2014 10:03 am
I stuffed recycled bottle insulation in all the cavities in my old van.
Toasty. Although the stuff i extracted from inside rear doors was soaked around the edges ! Dont pack it too close to edges !
Was bone dry inside mind, so Well worth doing!
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Postby RussC73 » Tue Dec 30, 2014 10:21 am
Some nice pics there, good job big brush... Is that a factory headlining ?
The pro fitted pics also look very nice indeed
RussC73
Postby Marcob » Tue Dec 30, 2014 1:42 pm
That's entrance matting. Any carpet shop should do it. You might even get it in B&Q.
Black 290 L2H1 125 PS Limited
The Ford Transit Custom - saving the environment by not actually going anywhere.
Zero emissions for 4 months and counting.....
Marcob
Postby obriencharlie123 » Tue Dec 30, 2014 2:14 pm
Doing a good Job big brush where did you buy that carpet ??
Using Tapatalk
obriencharlie123
Postby bigbrush » Tue Dec 30, 2014 6:32 pm
Hi, thanks for comments, headling i made out of 3,5 mm ply. made templates of edges with offcuts first, carpet is like veltrim i bought a big roll off ebay a while back have lined a movano out of it too, used veltrim in dark colour for bottom of doors and overcab, i have a removable bed which fits between both side racking just need time to finish it off. i know hi roof dont look as smart as low roof but suits my needs better.
bigbrush
Postby bigbrush » Tue Dec 30, 2014 6:42 pm
obriencharlie123 wrote:Doing a good Job big brush where did you buy that carpet ??
I notice yr not that far away from me i live near llantrisant, will get windows done like yours next
bigbrush
Postby obriencharlie123 » Tue Dec 30, 2014 10:27 pm
I got my windows off a guy in Doncaster South Yorkshire I can get you a number of you won't he does supply or supply and fit where did you buy your carpet as it looks the same colour and material as the roof and I need to carpet all my roof front to back as the joint in the middle mess it up ?
Using Tapatalk
obriencharlie123
Postby obriencharlie123 » Tue Dec 30, 2014 10:29 pm
obriencharlie123 wrote:I got my windows off a guy in Doncaster South Yorkshire I can get you a number of you won't he does supply or supply and fit where did you buy your carpet as it looks the same colour and material as the roof and I need to carpet all my roof front to back as the joint in the middle mess it up ?
Using Tapatalk
obriencharlie123
Postby bigbrush » Tue Dec 30, 2014 11:51 pm
The light grey carpet i had of a private seller on ebay they had it left over after doing a horse box, the dark one from seller upholstery-diy123 on ebay he got all colours, i had some windows for a renault trafic i converted and sold from van pimp they were quite good quality he is doing privicy openers for 150 supply only dont seam to bad. your van looks great.
bigbrush
Postby obriencharlie123 » Tue Dec 30, 2014 11:57 pm
Yeah Il try and get a pic of my openers tomorro if you won't and thanks for the info
Using Tapatalk
obriencharlie123
Postby RussC73 » Sun Jan 04, 2015 6:57 pm
Well today i made a start to insulate the inside of my van, I ended up purchasing x4 rolls of the foil bubble and x3 rolls of the recycled plastic insulation, for the vapour barrier i also got a roll of polythene.
Work in progress...
Once all the insulation has been installed i will attach the foil bubble to the rear of the after market ply for an added layer.
had a measure up of the one piece ply board i removed from the side section and its actually larger than 8x4, anyone know where i can purchase the same 3.5mm ply to do the roof? would be ince if i could fix it into place in one section.
RussC73
Postby bigbrush » Sun Jan 04, 2015 9:23 pm
HI.
Doing a great job , exactly as i did mine, i stuck the bubble foil to back off plywood, the roof is wider than the 1200 mm ply thats why i had to do mine in sections.
bigbrush
Postby RussC73 » Sun Jan 04, 2015 10:49 pm
bigbrush wrote:HI.
Did you cut your 8x4 sheet to make 2 sections (with a join)?
Tomorrow i will finish this off, going to use 3M double sided tape to fix the foil bubble to the roof sections - may even double the layers.
RussC73
Postby bigbrush » Mon Jan 05, 2015 6:38 pm
RussC73 wrote:
bigbrush wrote:HI.
Yes done in 2 sections cut ply to rough size used hardboard from bottom as template cut bottom out put in place and marked top. good luck
bigbrush
Postby RussC73 » Mon Jan 05, 2015 10:13 pm
Unfortunately my van never came with the hardboard headlining so its going to be lots of measuring and cutting with the jigsaw
RussC73
Return to Transit Custom
