Second Battery in Ford Transit Custom
Re: Second Battery in Ford Transit Custom
Postby ake » Sat Feb 07, 2015 7:07 pm
Mussels wrote:I don't have the stop start, the second battery is also a perquisite of a few other options. The split charge always charges the main battery first and moves on to the second battery and I've found before in winter electric heaters and lights mean there is a net loss sometimes and I'd like to charge up the second battery at home. This may be what prevents my heated screen from coming on sometimes.
I could only get to the negative terminal under the seat so I've connected the charger to the jump start point under the bonnet and it seems to be working. I don't know however if it's only charging one battery or how to check the voltage in either battery independently.
Jump start point charges start battery only.
Postby keeff » Sat Feb 07, 2015 7:41 pm
Mine had the twin battery's because of the power inverter option but it only works with engine on so why does it need the other one?
keeff
Postby Mussels » Sat Feb 07, 2015 11:50 pm
Hmmm, the batteries are covered with a large plastic molding so how do I charge the second battery?
I guess I'll have to remove more bits under the seat tomorrow and fit some extra leads.
Mussels
Postby Mussels » Sat Feb 07, 2015 11:51 pm
keeff wrote:Mine had the twin battery's because of the power inverter option but it only works with engine on so why does it need the other one?
Probably the inverter load is more than the alternator can cope with so it needs the feed from the battery at the same time.
Mussels
Postby moley551 » Fri Feb 20, 2015 7:54 pm
Hi, has anyone managed to get a price for the parts, I asked Vospers Roche and according to them its not possible!!!!!
"Don't find fault, find a remedy"
H. Ford
moley551
Postby ake » Sun Feb 22, 2015 5:16 pm
moley551 wrote:Hi, has anyone managed to get a price for the parts, I asked Vospers Roche and according to them its not possible!!!!!
Nonsense!
Just ask the parts dept to price the parts listed
Postby moley551 » Mon Feb 23, 2015 12:49 am
Thanks, Ake....we all know it's possible!! but Vospers are in a league of their own & the storeman is an absolute "legend" lol ....will give it a go tomorrow.
H. Ford
moley551
Postby VanConversion » Wed Mar 11, 2015 5:36 pm
ake wrote:Make sure you are seated when enquiring about the price :shock: :wink:
Ake, what sort of prices are we talking about? I was quoted £90 when I was enquiring about getting it factory fitted.
VanConversion
Postby moley551 » Thu Mar 12, 2015 11:24 pm
ake wrote:Yes you can, you need the parts listed below, and it needs configured using ford ids
Got some prices...take a seat!..the relay is £85....Bms harness £65....Bms connector for second battery £35...battery lead price not listed....nuts 70p each.
Add the price of a battery £100.....plus the workshop visit £80+
Jump battery fom Halfords £40? and no need to visit Vospers!!!!
H. Ford
moley551
Postby Mussels » Thu Mar 12, 2015 11:29 pm
Ouch, as a factory fit extra it's about £60 iirc.
Mussels
Postby factotum » Thu Apr 30, 2015 10:01 am
I'd also love to know the correct answer (to adding a charger to a dual battery Custom) as I'd like to incorporate a multi-stage charger in the power tool rig I have in the back so when the van in being used as a mains powered "command post" for an extended period on-site I can be sure that the batteries are kept charged...
Ford Transit Custom 2013 VN
factotum
Postby gianvi » Thu Apr 30, 2015 11:06 am
A question :
I will have the dual battery system on mine, seen that i will have start/Stop and the 220power inverter.
But seen that i will use also as Van for Holidays i will need (as on my VW) the solar panel.
I will connect it diretly to second battery or i must need some extra Tricks?
gianvi
Postby cowasaki » Tue Mar 20, 2018 11:41 pm
Which models come with dual batteries and if they are single how much does that lot cost? I've got an unused new 110 in the garage that I could use....
I'm buying a new Custom Limited 130 tomorrow (last of the old shape)
I've rebuilt a Defender, several motorcycles and quite a bit to both a Mk6 & 7 Transit. Now bought a new Custom and just doing a few small bits to it.
Cowasaki's electrical tutorials: viewtopic.php?f=2&t=166595
cowasaki
Postby Bladecom » Sun Apr 19, 2020 9:39 am
Hi Guys, I have a 2019 Transit Custom DCiV 2.0 eco start/stop auto, does anybody know if this has two batteries on it? the parts list shown below, are these Ford parts and if so are they good for a 2019 model.
Bladecom
Postby S60r » Wed Apr 22, 2020 10:22 am
It depends on the specification at build....
quickest way... slide your seat forward pop the cover and have a look.
S60r
Return to Transit Custom
