se7en wrote:I'm a Marine engineer, we are asked to fit extra batteries in boats a lot . the smart relay we always use is the " Victron Cyrix 12/24 battery combiner" imported by a company called Barden, this little unit is one of the best on the market and really simple and reliable in use,it will keep both batteries isolated from each other, however, one little trick it does is that it will connect both together if required for 30 seconds if required for boost starting,I have fitted one to my van ,its got me out of trouble a few times, if you Google in "victron cyrix" and click onto the fitting instuctions it will show a diagram and explain the set up, just thought this may help.
moley551 wrote:I was going to ask the same question myself, the cold nights are really putting a strain on my single battery, I have needed a jump start twice now after working with the side door open for a short time. Ford say it's my fault for trying to use a van for work!
Does anyone know if the Ford fitted second battery isolates the two batteries to preserve the start battery when parked so as the radio and various services do not drain it. I have a lesiure battery fitted in the back powering a Synergex 1500 watt pure sine inverter that is connected via a smart relay to the aux connection on the seat, this battery draws no power when parked but the internal lights (not Led) and other things will kill the battery very quickly.
Mussels wrote:I've got a factory fitted dual battery, how does that work with a charger?
Will it charge both with the split charge relay or do I need to connect directly to each battery in turn? Can I use the jump start position under the bonnet?
