I found these informations about the adaptor for AVIC (code CD-FOR-UAR.003):
Vehicle Bus Display Support through CD-FOR-UAR.003 for Ford
• This adapter has been designed to maintain a maximum of functionality when replacing the factory radio by a Pioneer AVIC product on certain FORD vehicle models. The UART terminal is used to convey the DEATC (Dual Electronic Automatic Temperature Control) status information functions only to the Pioneer AVIC for display purposes if the vehicle's original radio is supporting these functions. To avoid any problems, do not connect UART terminal other than with compatible vehicles.
• The FORD voice command system is not supported.
• Depending on vehicle configuration the screen dim function might not be supported.
• It is not possible to replace the FORD DVD Navigation System featuring a 17,8 cm/ 7“ touchscreen
• No data is sent to FORD Convers+ from AVIC.
Compatible Ford Models Ford B-Max 2013 > CD-FOR-UAR.003 Ford C-Max 2011 > CD-FOR-UAR.003 Ford Focus 2011 > CD-FOR-UAR.003 Ford Kuga II 2013 > CD-FOR-UAR.003 Ford Transit 2013 > CD-FOR-UAR.003 Ford Tourneo Custom 2013 > CD-FOR-UAR.003
if the function for heating control is real will be a good thing...
someone can confirm that ?
