Vorlich wrote:I have a Furry Box™.
Had a girlfriend with one of those.
Vorlich wrote:Thanks, I spent 2 hours tonight chiselling and cutting the panel off. I still have to remove the dabs of Sikaflex from the roof itself. Pretty grim job, I'll be using less Sikaflex when I fit the new panel!
I've ordered a 140w panel from photonic universe to replace the 95w Amperor one.
Hard to comment on your LEDs, there are quite a few on the D250 and MXS10.
It's worth checking out the PDF manuals on the CTEK website, remove the seat if you can and get a good look at it all. There are 4 hex bolts to remove. Just spin the seat slightly to access them, then it lifts off.
Softlips wrote:What's Years are the above affected vehicles?
Kennyb wrote:Hi not sure if all you wellhouse campervan owners are aware of an issue with the terminal blocks on the fuses located under the passenger seat ,there has been no recall as such as I only found out by accident my fridge packed up the other day and it had tripped the breaker switch in the cupboard and also blown a fuse under the seat ,I also noticed that two 30amp rated fuses were melted,fortunately I had the van booked in today for its 2nd habitation check and on arrival 9am was told oh yes we have had loads of problems blaming a faulty batch of boards but what's alarming is the NO RECALL notice surely this is a possible fire risk,so be aware check them fuses ,also I was told by the fitter it's affecting month old vans also
