Custom camper conversion
Re: Custom camper conversion
Postby vanvliet » Wed Aug 10, 2016 9:24 am
Thanks for posting an idea of costs much appreciated.
Swivel front seats really open up the dining area but you need to have a single passenger seat to do this .I fitted one to the passenger seat of a Mazda Bongo ( smaller than transit C) and it was brilliant to sit around both sides of the table - changed the whole feel of the van
vanvliet
Postby markjo618 » Wed Aug 10, 2016 11:09 am
I have a curtain to replace the bulkhead.
The swivel seat is a good option but my son likes to sit up front with us so we need the double seat i know you can swivel a double seat but looks a bit cumberson?
I have also bought a drive away awning and fitted some roof rails for this, hope to have a dry run putting this up over the weekend. Weather permitting. :D
markjo618
Postby dukey300 » Wed Aug 10, 2016 5:53 pm
Is the bulk head curtain bought off the shelf or have you 'custom' made it? I've just bought a drive away awning as well and hopefully testing it out this weekend.
dukey300
Postby markjo618 » Thu Aug 11, 2016 12:54 pm
The Bulkhead curtain is one of Van-X ones off the shelf you just have to cut the rail to size and drill mounting hole in it.
markjo618
Postby stooby69 » Thu Aug 11, 2016 6:32 pm
Nice job.Just what I'm thinking of doing.How did you find fitting units? Did they fit ok or did you have to mod.Did you do the electrics yourself?
stooby69
Postby dukey300 » Sat Aug 13, 2016 7:39 pm
That looks mint. I've just ordered a van-x curtain could you put me some pics on of where and how you've attached the rail and side attachments. Thanks sorry to be a pain
dukey300
Postby Camper steve » Sun Aug 14, 2016 11:35 am
dukey300 wrote:That looks mint. I've just ordered a van-x curtain could you put me some pics on of where and how you've attached the rail and side attachments. Thanks sorry to be a pain
I have used the vanx curtains too and you drill small holes in the rail then into the headliner. You then fit the rail to the headliner (making sure you dont drill the steel roof) with rivits. Vanx supply thr rivits but I used a different type (bulbex) which have a slotted shank and form a x when they get rivited. This makes for a much stronger rivit.
I did my curtains a while ago and had to cut bend and remake a T5 set but method of fitting is the same.
Camper steve
Postby loko » Sun Aug 14, 2016 6:05 pm
I do like that, is there enough room in a swb to do this setup?
loko
Postby Softlips » Sun Aug 14, 2016 8:14 pm
loko wrote:I do like that, is there enough room in a swb to do this setup?
Yes
Softlips
Postby markjo618 » Mon Aug 15, 2016 12:47 pm
It is a SWB
Few pics withe the awning attached.
markjo618
Postby loko » Mon Aug 15, 2016 10:11 pm
markjo618 wrote:It is a SWB
Ah right thanks, im looking on the phone so couldnt really see, anyway top work, very impressed
loko
Postby moley551 » Mon Aug 15, 2016 11:17 pm
Where do you keep your gas,
"Don't find fault, find a remedy"
H. Ford
moley551
Postby markjo618 » Tue Aug 16, 2016 3:14 pm
Will be using a gas BBQ for cooking the van cooker will be for the odd cup of tea or light meal. I have left the gas hose on the hob long enough to connect upto the BBQ canister.
markjo618
Postby moley551 » Tue Aug 16, 2016 6:26 pm
Don't want to rain on the parade so to speak.. but I've seen quite a few that don't comply with the regs, my van insurance only allows 1kg of LPG (blowlamp) to be carried inside the van.. Gas bottles should only be carried in purpose built gas lockers vented to outside. Believe me I'm not a safety sally but I see some really well built potentially disastrous DIY jobs every week .
H. Ford
moley551
Postby dukey300 » Tue Aug 16, 2016 7:51 pm
Which awning is that? It looks really smart.
dukey300
Return to Transit Custom
