se7en wrote:Apart from the Cyrix split charger unit you will need suitable cable and terminals, and if you want to use the " 30 second battery link feature" you will need a push button momentry switch, I've mounted my push switch in the front of plastic hand brake lever base surround , I put it there as its close to the batteries , I have both batteries under the driver seat ,easy to fit, and within reach if you need to use it, oh, and nobody notices it.
Look at the wiring diagram on Victron energy site, tells you all you need to know.
