slikt wrote:So what would be the recommended one to run an amp off? Cheers
jasonx wrote:slikt wrote:So what would be the recommended one to run an amp off? Cheers
The customer connection point is recommended
slikt wrote:So I've found the aux connection, is there a maximum amp draw off those?
jasonx wrote:slikt wrote:So I've found the aux connection, is there a maximum amp draw off those?
60 amps,well each stud is fused for 60 amps but you probably only have one stud
slikt wrote:jasonx wrote:slikt wrote:So I've found the aux connection, is there a maximum amp draw off those?
Cheers Jason. Could I take a supply direct from the battery that has the small plastic Velcro access cover? I only ask as the amp I'm fitting needs an 80amp fuse and I don't want the 60amp fuse blowing in case that affects the running of the van (it's highly unlikely I'll blow it, but want to be safe). HNY mate
