mavericktc wrote:As discussed, how long since you zeroed it?
It's not accurate enough that you can reset it at each fuel up.
Mike wrote:mavericktc wrote:As discussed, how long since you zeroed it?
It hadn't been zeroed for over 10k miles and it's showing very close to the genuine mpg figure. If you reset it every tankful it'll only be accurate for that tank. Why would it be accurate over 10k miles but inaccurate over 600miles?
Mike wrote:Of course, if we're talking about an average. More data = more accurate results. The short term results won't be miles out though. If you average 1 tank your results will be affected by how full you fill the tank, it's your results that will be off, not the vans computer. It's all very well saying you fill it until the pump clicks off, but different pumps fill at different rates, so they'll click off at different times.
mavericktc wrote:Because it isn't? I've tried it so many times that I lost count. Even you said that it's more accurate over time;
mavericktc wrote:
A difference in 7 liters between full fillups is impossible.
Who said it was possible?
I didn't say that. I also said thismavericktc wrote:You because that's how much it's off if the happy-o-meter is correct.
when I replied to Deano.Mike wrote:Just because yours is sh*t..
Mike wrote:I didn't say that. I also said thismavericktc wrote:You because that's how much it's off if the happy-o-meter is correct.when I replied to Deano.Mike wrote:Just because yours is sh*t..
I was pointing out that just because some seem to be unrealistic doesn't mean that they all are. Also, as ponted out by others (not just me) it's extremely difficult to fill up to exactly the same point every time. So using the Road Trip takes out the inaccuracies, and in my case shows that the van mpg readout is all but spot on.
But feel free to keep banging on
