Frag wrote:Window switch hooks under the door panel at the front edge of switch.
Push a small screwdriver under rearmost edge of switch in the centre to release the retaining tang ,then prise it up carefully at rear edges.
Frag wrote:Clip fits with sponge towards you,shiny flat side to the door skin.
khould wrote:With rhe newmlock do you loose the facility of using the keyfob to open and lock the van, or do you lock it with a key
Kev
SteveOh wrote:Hi SR60.
No, i'm just trying to make it harder so the toe rags walk on to the next Custom..
S60r wrote:SteveOh wrote:Hi SR60.
Yeah I agree, I think I'll copy you, how much did you pick one up for in the end?
Cheers Steve
SteveOh wrote:khould wrote:With rhe newmlock do you loose the facility of using the keyfob to open and lock the van, or do you lock it with a key
Kev
Kev you can still use the fob....it just stops toe rags picking it
