How to remove drivers door panel to replace lock with hykee
Postby SteveOh » Wed Feb 08, 2017 2:10 pm
Hi Fellas.
Can anyone help me with the info on how to replace the existing lock with the Hykee lock?
Taking off the door panel
Removing Existing lock
Fitting replacement
thanks for any help
it's all shits and giggles until someone giggles and shits
SteveOh
Re: How to remove drivers door panel to replace lock with hy
Postby Mike » Wed Feb 08, 2017 2:44 pm
That's a fvcking annoying avatar.
edit: You can turn off avatars :mrgreen:
Mike
Wind up merchant!
Postby Altransit » Wed Feb 08, 2017 2:55 pm
Postby Mike » Wed Feb 08, 2017 2:58 pm
Altransit wrote::arrow: viewtopic.php?f=18&t=113421
What, there's a search function here? I could have used that to find out how to disable avatars :oops:
Mike
Wind up merchant!
Postby Altransit » Wed Feb 08, 2017 3:01 pm
Mike wrote:What, there's a search function here?
Only moderators can use it ............................... apparently :P :mrgreen: :lol:
Postby FlyCatcher » Wed Feb 08, 2017 5:35 pm
SteveOh wrote:Hi Fellas.
Fitting replacement
thanks for any help
Good question , I am also trying to find out how to do this, nothing on you tube yet. HELP NEEDED
FlyCatcher
Postby jasonx » Wed Feb 08, 2017 10:23 pm
Fitting replacement
thanks for any help
https://www.pdf-archive.com/2017/02/08/ ... -cylinder/
password is doorlock
jasonx
Postby Wadey » Wed Feb 08, 2017 11:31 pm
Mine came with instructions and pictures didn't yours?
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Postby Altransit » Thu Feb 09, 2017 1:30 am
Wadey wrote:Mine came with instructions and pictures didn't yours?
Mine didn't, I used the thread that I linked to above, to do mine, but my lock was easier to fit than Rumblebee's, and didn't need to be modified 8)
Postby SteveOh » Fri Feb 10, 2017 8:30 am
Thanks Wadey.
Any pointers on taking this door trim off??
SteveOh
Postby FlyCatcher » Sat Feb 11, 2017 10:28 am
How many torx screws/bolts hold the door card on , i have found 5 only.
FlyCatcher
Postby SteveOh » Sat Feb 11, 2017 12:49 pm
FlyCatcher wrote:How many torx screws/bolts hold the door card on , i have found 5 only.
I've found this info in another post about speakers.
http://fordtransit.org/forum/viewtopic.php?f=65&t=136220
9 screws in all
2 in handle t25 torx
2 at bottem,t20
2 behind little round covers t20
1 behind reflector t20
1 under window switch t20
1 in the door opener handle area t20
SteveOh
Postby FlyCatcher » Sat Feb 11, 2017 1:50 pm
9 screws in all
2 at bottem,t20
Thank you this will be a great help for many forum members
FlyCatcher
Postby dunf » Sat Feb 11, 2017 5:02 pm
To get the top centre screw you just pop out the window switch housing.
dunf
Postby FlyCatcher » Sun Feb 12, 2017 10:34 am
9 screws in all
2 at bottem,t20
IS THIS THE DOOR CARD OF THE TRANSIT OR THE CUSTOM ???
FlyCatcher
Return to Transit Custom
