Make your Custom a lot more secure for free!
Re: Make your Custom a lot more secure for free!
Postby stchris356 » Mon Mar 20, 2017 3:03 pm
Chrisp74 wrote:Nice mod. Thanks for the share.
Do we think it will be the same wire on new Transit? (66 plate)
Mines a brand new 66 plate
Sent from my SM-G935F using Tapatalk
stchris356
Postby Chrisp74 » Mon Mar 20, 2017 3:57 pm
Sorry mate. I mean Normal Transit not Custom.
Chrisp74
Postby bigjohnthomas » Mon Mar 20, 2017 3:59 pm
stchris356 wrote:They don't have to do that, Once they've unlocked it from the door lock it unlocks all the other doors and turns the alarm off!
Are you sure about this young man ?
Switching the alarm off by opening the door with the key ? That's not how the old mk7 tramps van alarm works
Open with the key and you've got about 15 seconds to put a chipped key in and turn the ignition in or whoooop whoooop the alarm goes off
I shall be checking when I get home you know
Regards
Mum
bigjohnthomas
Postby stchris356 » Mon Mar 20, 2017 4:13 pm
Regards
Mum
Pretty sure, I checked that on mine before I did the mod, that said, the aim was to stop the rear doors being unlocked. It even said in the handbook that the alarm will trigger if opened with the key blade only, it didn't on mine pre mod !
stchris356
Postby bigjohnthomas » Mon Mar 20, 2017 5:50 pm
Now then son ...
I have conducted a series of scientific tests on this and here are the results
Open the door with the key beep beep alarm goes off whoop whoop
Open with key and move key into cab and beep beep stops and alarm is switch off
So you don't need to put the key in the ignition just in the cab
Weird sh*t init
Anyway mummy's going to smack your bott bott till its all Hurty :P
bigjohnthomas
Postby bigjohnthomas » Mon Mar 20, 2017 5:59 pm
Just went off when I spend the door that time
Bonkers
bigjohnthomas
Postby bigjohnthomas » Mon Mar 20, 2017 7:33 pm
https://youtu.be/J7v3e0w9yYQ
So it will stop the back opening but the alarm will be going off :?
Won't make much difference to my van though :P
It used to belong to a vicar and he used it for storing his Nazi gold you knowImage
bigjohnthomas
Postby stchris356 » Mon Mar 20, 2017 7:40 pm
bigjohnthomas wrote:https://youtu.be/J7v3e0w9yYQ
That's the desired effect, yes ! How else is my Rottweiler going to know dinners ready ?
stchris356
Postby cjchris » Wed Aug 02, 2017 6:43 pm
Hi does anyone know what the last cable does because on another site they said cut the last two wires which i have done and the only difference is there is no delay with the alarm basically you dont get the 15 seconds its instant which i think is better so it must be a delay trigger wire.
cjchris
Postby stchris356 » Fri Aug 04, 2017 6:48 pm
cjchris wrote:Hi does anyone know what the last cable does because on another site they said cut the last two wires which i have done and the only difference is there is no delay with the alarm basically you dont get the 15 seconds its instant which i think is better so it must be a delay trigger wire.
I don't, but that's interesting. I'll see if I can find out.
stchris356
Postby man le-mans » Thu Aug 10, 2017 9:05 pm
Is this only on the custom, any ideas if it's the same on the mk7
MK8 L2H2 T350 TREND 68 plate silver 130bhp
Mk7 MWB M/R T350 TREND 2010 SILVER 115BHP
MK7 MWB M/R T350 2009 BLUE 115BHP (crap)
MK6 MWB M/R T280 full electric pack silver 2003 85BHP
Smiley face T reg L/R SWB ex BT
man le-mans
Postby Flatfour1 » Fri Sep 01, 2017 9:23 pm
This may be of some use/help to some of you.
http://www.parkers.co.uk/vans/news-and- ... ty-update/
Flatfour1
Return to Transit Custom
