jasonx wrote:Cant the thieving scum bags just press the unlock button once they open the door ?
Backbone of Britain wrote:And when your fob stops working for any reason you also can't get into the rear of the van !!
stchris356 wrote:Backbone of Britain wrote:And when your fob stops working for any reason you also can't get into the rear of the van !!
You can if you turn the ignition on and press the unlock button on the door !
Sent from my SM-G935F using Tapatalk
Backbone of Britain wrote:So what stops the thief doing exactly the same then??
Mike wrote:Backbone of Britain wrote:So what stops the thief doing exactly the same then??
Well presumably the alarm will be going off and the thief won't have the ignition key?
roughtech wrote:Great job...cheers. just wondering if that wire could be located easily at the steering column for a switch fitment?
Sent from my SM-G900F using Tapatalk
