Hi all,
I'm pondering the maintenance of my 2013 transit custom. I'd like some of your opinions on the following.
I know from this board the many different problems people have with their TC's. From stalling in slow traffic to the oil level rising from diesel in the oil. I've also read countless times that after a service from Ford, the vans quite often drive much less nice/economical than they did before for either quite some time or sometimes permanently.
My van is driving very well. No problems, no complaints at all, regarding the issues I've learned about from here. My code reader tells me there hasen't been a single code stored in the 11 months I've had the car. I count myself lucky at that. It's had the required oil pump changed and it's had the major pcm/ecu update the early ones needed. It was official dealer serviced for the first 44.000 km's. The worst thing I could say about driving this van is that it seems to be far from as fuel effcient as it is claimed to be. Without Aircon it's a steady 10,5km/l, with highs of 11,5 max when longer distances are done. Switch on the aircon and at the legal 130km/h limit the van does about 9,5km/l max. Unfortunately I do mostly relatively short runs.
But apart from that it's great.
Now, I bought my van from an independent dealer. They gave the car a full service as part of the deal as ford would have. They are a bosch place so they use bosch parts. For peace of mind I'd like to give the car a full service yearly. And with that I mean independant of mileage I just want a service covering all filters (fuel, oil, interior), engine oil, full check up of brakes and pads all round and any other things that belong to a decent service. They are a reliable workshop where trust and service still mean something.
Now the prices at this independent dealer are far more reasonable than those at Fords. The only real difference I see between them is that this independent dealer will not be able to update the PCM/ECU if need be. But is that enough reason to go to Fords? And how do I know if there even is an update? And if there is, should one always apply them? As said I don't want the engine to run less nice than it does now. But I can also imagine ford having learned a few things about the engine over the past years that have resulted in software updates improving the longevity of it. And seeing I have to run this van for at least another 7-9 years....
So that's where you come in, what is your opinion on the matter?
Thanks,
Alex
