just got my transit and the phone works ok but it will not read out my text messages
using a iphone 6s
does anyone else have the same trouble?
S60r wrote:I haven't tried it through the sync.... I'm not sure it will do it with iPhone.... the Ford system is ok but a bit basic.
I use Siri.
Pull the voice control paddle on the right side of the steering wheel. A quick pull and release gives you sync and a long pull and hold will activate Siri.
Once Siri asks you through the speakers what you require, get him to read out the messages.
If you can't get the long pull to work, go into CarPlay settings on the iPhone and follow the instructions at the bottom. It will require you to pull and hold the paddle until Siri recognises it.
"Hey Siri" also works if you find the paddle method difficult.
ake wrote:Pretty sure the Ford site states that text message reader is not compatible with I phone
