Removing inner lining/inside roof.
Postby mavericktc » Mon Apr 10, 2017 10:52 am
Has anyone tried to remove the roof lining in the cab (single cab) equipped with side airbag curtains?
mavericktc
Re: Removing inner lining/inside roof.
Postby mavericktc » Sat May 20, 2017 8:16 pm
BUMP!
I'm done with the sound deadening in the doors so now it's only the roof left.
mavericktc
Postby vanvliet » Sun May 28, 2017 9:45 pm
What is the best /cost effective sound deadening material to use?
vanvliet
Postby S60r » Mon May 29, 2017 8:28 am
Sound deadening! Don't use that butyl roofing crap.
Loads of really cheap sound deadening on eBay.... I got a large roll of Vibe deadening for 20 quid so no need to "make do" with something that isn't fit for purpose. The roll would easily do one entire door with a bit over.
This does 3 square metres and is top quality stuff at 6mm but you can get 2/3mm for way less the DODO stuff is really good.......
http://www.ebay.co.uk/itm/6m-Roll-Car-V ... Sw6DtYWnbL
S60r
Postby bigjohnthomas » Mon May 29, 2017 9:41 am
What's the stuff ford use then?
It wouldn't be that butyl roofing crap like stuff would it?
:P
viewtopic.php?f=4&t=179943
bigjohnthomas
Postby bigjohnthomas » Mon May 29, 2017 9:42 am
I wish I had put some of that foil stuff of yours in the back of mine
Bloody loads of road noise in there
bigjohnthomas
Postby mavericktc » Mon May 29, 2017 10:59 am
I used roadkill expert in my doors.
Cheaper then dynamat but thicker.
mavericktc
Postby loot » Tue May 30, 2017 10:55 pm
I saw roadkill and for a second there i thought the worst :lol:
07 350 170ps
Ids map here
loot
Return to Transit Custom
