Latest nav software
Latest nav software
Postby dug1001 » Fri Apr 28, 2017 9:46 am
Hi all,
I've just had a new custom DCIV delivered yesterday and the sd card for the navigation isn't in the slot.
Does anyone know what the latest version should be? I'll get the dealer to post one to me but I want to make sure it's the latest one available.
Cheers,
Peter
dug1001
Re: Latest nav software
Postby John Johnson » Fri Apr 28, 2017 10:04 am
Mine states V5 which is a van from last July
John Johnson
Postby loot » Fri Apr 28, 2017 10:24 am
Mines 2015, went over a roundabout weds that was a cross roads :(
Is there a way to sync update the sd card? Can a new sd card be copied over mine? Or are they secured to each van on installation?
Ids map here
loot
Postby devilman » Fri Apr 28, 2017 1:47 pm
I bought a new one off eBay after reading up on here. Came from Latvia I think. You can't update without buying the ew SD card. There were a few anxious moments when it reprogrammed the whole system but it was fine after. Mine is on 2016.
devilman
Postby dug1001 » Sat Apr 29, 2017 7:47 am
John Johnson wrote:Mine states V5 which is a van from last July
Ok thanks John. A quick look on eBay showed some V6 ones listed, wonder if there's a newer one. I assume they update them annually.
dug1001
Postby dug1001 » Sat Apr 29, 2017 7:51 am
loot wrote:Mines 2015, went over a roundabout weds that was a cross roads :(
Haha to be fair that even happens to me using Google maps.
It would be nice to update the sync. This 2017 van uses Siri via my iPhone which is handy.
We've also got a '64 plate Custom and it'd be nice to be able to do it on that one.
dug1001
Postby dug1001 » Sat Apr 29, 2017 7:53 am
devilman wrote:I bought a new one off eBay after reading up on here. Came from Latvia I think. You can't update without buying the ew SD card. There were a few anxious moments when it reprogrammed the whole system but it was fine after. Mine is on 2016.
Hi loot, do you mean you bought a newer version of the nav software on an sd card and it also updates the whole sync software or just the nav software?
Cheers.
Peter
dug1001
Postby loot » Sat Apr 29, 2017 7:58 am
No my van is December 15 (65plate) i have the Ford sat nav sd card for 2015 for it which just goes in the slot, it has like advd case for it like a computer game, i never used it first as far as i know so i don't know if they get initialized and locked to the radio??
I'll find out at some point I'm sure.
Ids map here
loot
Postby S60r » Sat Apr 29, 2017 8:40 am
Mine is a 65 plate and the sync uses Siri and google maps so makes the oem Nav redundant. You don't need a 2017 van to utilise Siri and the iPhone mapping.
S60r
Postby dug1001 » Sat Apr 29, 2017 11:51 am
S60r wrote:Mine is a 65 plate and the sync uses Siri and google maps so makes the oem Nav redundant. You don't need a 2017 van to utilise Siri and the iPhone mapping.
We got a 65 plate too which doesn't use Siri. That's what I'm wondering whether that one can get updated. That van doesn't have the sat nav built in.
dug1001
Postby Mike » Sat Apr 29, 2017 12:43 pm
Are the differences between Sync 1,2 & 3, software or hardware based?
Mike
Wind up merchant!
Postby dug1001 » Sat Apr 29, 2017 7:13 pm
Sorry that meant to say 64 plate that doesn't use Siri not 65 plate..
The nav software arrived today, its V7
dug1001
Postby mavericktc » Sat Apr 29, 2017 8:28 pm
Mike wrote:Are the differences between Sync 1,2 & 3, software or hardware based?
Sync 3 must be touch as far as I know.
99.9% of all sync 1 are probably non touch.
mavericktc
Postby devilman » Mon May 01, 2017 12:43 am
Cheers.
Peter
As far as I can remember it updated the whole thing, SYNC included. The icons and font size were different after, although that may only have been the GPS icon. I got the exact model number to order from this forum and googled it. Ford were charging £140ish and I paid a whole lot less.
devilman
Postby sparker000 » Tue May 02, 2017 2:49 pm
I have just ordered the latest version of MFD Navigation software for the sync1 Custom. I believe it has just been released, each year it is on the 1st March.
Parts no. 2093759.
2017 V7.
When it comes, is it straight forward to install? Manual says, "for updates speak to a Ford dealer".
When it is up and running I will give it a while and then let you know if there is any improvement on the 2015 V5 version I have now.
sparker000
Return to Transit Custom
