Tow bar with reverse sensors
Postby mufcpaul74 » Mon May 08, 2017 9:05 pm
Hi, I'm looking to have a tow bar installed on my custom, just wondering if there is a certain tow bar I need to have fitted due to parking sensors. Thanks in advance
Paul
mufcpaul74
Re: Tow bar with reverse sensors
Postby Wadey » Mon May 08, 2017 10:33 pm
Any of the tow bars made for a custom will fit none of them that iv seen cover the sensors
You will need the vehicle specific wiring though iv just had a witter removable one fitted to mine as I don't want it too look a builders van it's a very tidy set up. it's almost invisible if you don't have the hitch in
The wiring plugs into a cambus interface that's under the passenger plastic step cover
My mate who fitted it plugged in his programmer and updated something in the bcm so it disables the rear sensors when the socket is used , instead you get a picture of a trailer attached on the dash instead of the rear sensors in the display
Hope this helps
just follow the onscreen instructions and it's fairly idiot proof...trouble is, we keep producing better idiots
Wadey
Return to Transit Custom
