S60r wrote:If it doesn't sort it, I'll wire you the money back across.
Greenoval
findlay1980 wrote:There will be a number of variables to consider whether or not S/S will activate (my problem was that is activated while I was still moving, worringly), the dealer unplugged the module and plugged it back in and it's been fine since. As best I understand the software will consider the following in the calculation:
Ambient air temperature
Oil temperature
Coolant temperature
Engine load (aux power, a/c etc)
Battery Charge
So, if it's below, say, 5c ambient but the engine is up to temperature SS won't work
If it's 20c air temp but the engine temps aren't high enough, SS won't work
etc.
