Air con
Re: Air con
Postby get connected » Thu Jun 08, 2017 9:11 pm
It says... something about European guidelines... thank God for Brexiy I say ;-)
Sent from my SM-G900F using Tapatalk
Keep a smile on your face at all times! The others think you know something that they don't !!!
get connected
Re: Air con
Postby Camper steve » Fri Jun 09, 2017 3:14 pm
Ok folks, have got ut back from fords after a full regass and vent flush.
Mine is a tourneo custom with twin aircon, one unit in front and one in the back. This uses 1.1kg of r1234 type gas (the new expensive gas)
Ford cost £372 including the vat............×#!&#@÷×*"/$#?*€^%king hell!
Camper steve
Re: Air con
Postby loot » Fri Jun 09, 2017 4:06 pm
:shock:
Ah is only money mate, don't really need food or clothes as they're a bit frivolous aren't they :lol:
I think you'll want to get your moneys worth tho, full blast in the winter and if anyone complains they can jolly well get out and walk :lol:
07 350 170ps
Ids map here
loot
Re: Air con
Postby JethroFlint » Fri Jun 09, 2017 4:54 pm
get connected wrote:It says... something about European guidelines... thank God for Brexiy I say ;-)
Ooops! Not quite, yet another false understanding with respect to the EU. Nothing will change after Brexit as we helped to push the change.
"The UK ... has played a key role in developing EU-level
mechanisms to control emissions ..." .
https://www.theccc.org.uk/wp-content/up ... r-2016.pdf
Sorry to burst your bubble.
125 270 Limited
JethroFlint
Re: Air con
Postby bigjohnthomas » Fri Jun 09, 2017 5:21 pm
Bloody eu :x
bigjohnthomas
Re: Air con
Postby thedugmaster » Sun May 06, 2018 6:58 am
Camper steve wrote:Ok folks, have got ut back from fords after a full regass and vent flush.
Holy feck!!
Mine's got the same issue and is in with Ford for the air con and an MOT next month!
I hope they don't charge me that much!
thedugmaster
Re: Air con
Postby mistericeman » Sun May 06, 2018 10:41 am
Mike wrote:
Camper steve wrote:
apparently the sealed part of the system contains the refrigerant which is mixed in with a lubricant oil. when you don't use the system for a while the rubber seals go dry as the oil is not being pushed around the system with the refrigerant, this then leads to leaks due to dry seals.
If that was the case you think it'd affect the air source heatpumps that some of my pools use. They sit for 6 months without use, and it's basically the same system.
Not unless they are running 'open/semi open' compressors theyre not....most stuff barring industrial sized stuff runs hermetic compressors (sealed ) like your fridge at home .
Sadly automotive compressors are rotary belt driven from the engine (barring the odd vintage american 12v hermetic)and rely on a simple rubber seal to keep the refrigerant in the system .
Folks dont bother to run their aircon in winter and the seals dry out followed by no gas in the system shortly after .
mistericeman
Re: Air con
Postby moley551 » Sun May 06, 2018 2:38 pm
My aircon is left on continuously, the van has done 90k miles and was made in Oct 13, it's never been topped up and still works perfectly. I've got a mate who works on lorry fridges and he needs a favour, I guess I've just found the price. :D
"Don't find fault, find a remedy"
H. Ford
moley551
Re: Air con
Postby mistericeman » Sun May 06, 2018 4:41 pm
Mike wrote:
Jvic28 wrote:Air con regass is only covered for 12 months.
Could you explain why?
Because even IF a full check of the system is made (recover refrigerant/pressure test/evacuate)
There's no possible way that you can guarantee that a component isn't going to fail....
Frankly I wouldn't guarantee vehicle aircon after it left my hands...
mistericeman
Re: Air con
Postby Mike » Sun May 06, 2018 4:56 pm
That has to be among the top 10 most stupid things ever posted here......and we’ve had some real shite over the years. I really do despair at the ever declining standard of posters.
Mike
Wind up merchant!
Re: Air con
Postby bigjohnthomas » Sun May 06, 2018 5:49 pm
Mike wrote:That has to be among the top 10 most stupid things ever posted here......and we’ve had some real shite over the years. I really do despair at the ever declining standard of posters.
Very true my good fellow just look at the stupid shite this person spouts
search.php?author_id=3570&sr=posts
That's you that
Lolzzzzzz
bigjohnthomas
Return to Transit Custom
