It says... something about European guidelines... thank God for Brexiy I say
Sent from my SM-G900F using Tapatalk
get connected wrote:It says... something about European guidelines... thank God for Brexiy I say
Camper steve wrote:Ok folks, have got ut back from fords after a full regass and vent flush.
Mine is a tourneo custom with twin aircon, one unit in front and one in the back. This uses 1.1kg of r1234 type gas (the new expensive gas)
Ford cost £372 including the vat............×#!&#@÷×*"/$#?*€^%king hell!
Mike wrote:Camper steve wrote:
apparently the sealed part of the system contains the refrigerant which is mixed in with a lubricant oil. when you don't use the system for a while the rubber seals go dry as the oil is not being pushed around the system with the refrigerant, this then leads to leaks due to dry seals.
If that was the case you think it'd affect the air source heatpumps that some of my pools use. They sit for 6 months without use, and it's basically the same system.
Mike wrote:Jvic28 wrote:Air con regass is only covered for 12 months.
Could you explain why?
mistericeman wrote:Mike wrote:Jvic28 wrote:Air con regass is only covered for 12 months.
Because even IF a full check of the system is made (recover refrigerant/pressure test/evacuate)
There's no possible way that you can guarantee that a component isn't going to fail....
Frankly I wouldn't guarantee vehicle aircon after it left my hands...
Mike wrote:That has to be among the top 10 most stupid things ever posted here......and we’ve had some real shite over the years. I really do despair at the ever declining standard of posters.
Users browsing this forum: omarmekic
