Camper steve wrote:Hi All
am sure i read before that someone had smelly aircon.
Myself i have a system that is not cooling the van down, so i asked around some mobile aircon service people for prices and have learnt a great deal....
My 64 plate uses just over 1 Kg of R1234yg gas, and this is a new type of gas which the government have made car manufacturers use from 2014 onwards.
older vans use R134a gas which is cheap! (can get a regas/aircon service at around £50)
The new gas is bloody expensive and i have been quoted at around £300 per kilo for the gas alone.
So i rang ford and asked to see if i could have the van re-gassed and diagnosed for leaks on warranty. I was told by the lady that ford recommend a regas at every 3 years and it was not likely to be under warranty as it will have used the gas up in 3 years. I pointed out the aircon system is a sealed system and that the gas does not get used up like fuel. the only way it can lose gas is if it leaks, i also asked her when was the last time she had her fridge at home re gassed as it was the same system, all be it that the van has a fan on the cold end of the system to push the cold around the van. this is when she offered me a aircon service, diagnostic and cleanse for just £79 including picking up the van and bringing it back. considering others had quoted me around £400 all in i said yes, i know i should have pushed for a warranty fix, but at £79 im not arguing as long as i get my van sorted.
Lesson here is that if your van is nearing its 3 years, ask for the aircon service as part of your service, if you still use ford. on the face of it its a lot cheaper if they do it.
am still going to be waiting for a call when they have mine in though for them to try to tell me its going to cost more than the £79 they quoted me..... We will see!
bigjohnthomas wrote:If you don't run the air con every few minutes the seals dry out and all the gas f*** off
Same with fridge vans and trailers
Use it or loose it dude
I should know I am a scientist
Regards
Prof smallcock kk
Camper steve wrote:Mine is definitely the R1234yf as it has the sticker under the bonnet detailing it.
Jvic28 wrote:Air con regass is only covered for 12 months.
Jvic28 wrote:Personally I would offer you some goodwill and carry it out under warranty anyway. In the hope of course that you'd have faith in us as a dealer and return for future maintenance.
Jvic28 wrote:Have you called customer relations?
