Camper steve wrote:just interested to hear why a sealed system lets gas out and then the owner gets charged for having it fixed.
apparently the sealed part of the system contains the refrigerant which is mixed in with a lubricant oil. when you don't use the system for a while the rubber seals go dry as the oil is not being pushed around the system with the refrigerant, this then leads to leaks due to dry seals. (or so i'm told) van goes in on Friday will let you know what happens, and how much they charge me. (or try to)[/quote]
That's basically what I was told - you have to use it regularly to stop it drying out and leaking.
I don't use mine that mush normally, so I try and remember to switch the aircon on every Friday on my way home from work - give a regular run.
Did that for the last 5 years on my previous Mondeo and never needed it regassing
